Measuring Tapes/Reels/Chains
IdahoMan
Looking for a reel tape-measure in several hundred feet. Examples:
Pittsburgh(HF) 330': $17
Lufkin 300': $50
Milwaukee 100': $30
1. Is there really going to be a difference in accuracy between the brands?
2. Anybody had one fail, and if so how?
3. Anything I should consider when purchasing one?
Thank you.
The Cobbler
I don''t think accuracy would be a concern on any of them.
how often will you be using it? I have one that has been used about 20 times . I think if you're using it all day everyday reliability would be a concern, if it gets uses occasionally, I suspect any of them will hold up .
Marctrees
TX/LA border - Toledo Bend
Over longer distances steel will have a more finite definate stretched taut feel than non steel.
BE AWARE not all tapes wil read the same especially the farther you go.
Not knowing that can make you go down crazy rabbit holes when 3 4 5'ing like a foundation.
Marc
JoeMcGov
Birmingham, Alabama
Lufkin 300': $50
Milwaukee 100': $30
Thank you.
Yes. How accurate do you need to measure??
NUTTSGT
Northern Central Ohio
If you are laying out a large building or need to be "exact", I'd suggest steel. If you need two of them for layout, get 2 of the same to be the most consistent.
Marctrees
This is VERY important - Gonna repeat -
"BE AWARE not all tapes will read the same especially the farther you go.
***** - Not knowing that can make you go down crazy rabbit holes when 3 4 5'ing like a foundation."
Marc
I
IdahoMan
Marc
You mean two tapes will be off if held side by side at far distance, or that a single tape itself will have inconsistencies?
Marctrees
Your question slightly confuses me...
I'll explain how I learned...
We were laying out for a 35 x 38 pole barn...
Had one 100 tape stretched on S side, and another guys 100 cloth tape stretched on the W side.
Doing 3 4 5 squaring at like 27, 36'... Looking for 45 +- 1/4".
Trees and retain wall did not let us measure larger than the building size.
Weird stuff started happening... We spent more than a few hours slightly adjusting stuff and scratching our head cause stuff was a bit off when we double checked both diagonals.
Said screw it and try again tomorrow.
Turns out all three tapes read a little different when later laid side by side.
All three were relatively new and never abused in any way.
All were "Brand Name" ... not that that means much.
So, check the "Synchronization" of ALL of your tapes before you start.
Kind of like the Law of using the same measuring tool when doing a job...rather than swapping off... if practical of course.
Let alone when a Newbie is on the job that hasn't yet figured out one side is tenths and the other side is inch. :lol_hitti
Marc
vavet
Ashland, VA
I bought a 300’ Kobalt reel for landscaping measurements. The only issue I’ve had with it is losing it. As long as you can keep track of it, it’ll be fine. I can’t speak to its accuracy or precision. It’s close enough to not raise any red flags for me,
PureLeaf
Some tapes actually state they're made to certain measuring specifications for what good that is worth. Fisco specifically comes to mind
neophyte
Pennsylvannia
Lufkin 300': $50
Milwaukee 100': $30
Thank you.
I presume there are accuracy standards to which US “made” or sold tapes have to be made, but I’ve rarely seen US manufacturers mention what thise accuracy standards are in their literature or on their websites.
Some Starrett tapes used to come in versions with ceryified accuracy, but these were soecialty models.
The only manufacturers I’ve usually seen list accuracy standards for tapes and folding rules are European manufacturers like BMI from Germany, and Hultafirs/Talmeter from Sweden and Fisco from the UK.
Typically these come with acurracy standards such as class II or class III, which are marked in the tape or rule, and which specify maximum deviation from standards between individual marks on the rule, as well as the total lengths, or at set distances.
The Euro made tapes seem to be somewhat thinner than brands made for the USA though, so I’m not sure whether they would be better for heavy use.
For best accuracy you would really want a laser measuring device, such as a Hilti or Leica laser distance measurer. The ones made for longer distances are probably good for 1/10 of an inch or less over hundreds of feet.
If you don’t need massively accurate measurements, your better off trying to figure out which manufacturer makes the long **** with the more functional housing. The way the tape stores and reals back in, or locks, as well as the durability of the tape and markings will likely be more important for use than a tape being out of measurement by an inch over 100 feet.
If an inch over a 100 feet is crucial, you’re going to need to invest more in measuring devices, probably including a decent transit si you can use geometry to help verify measurements.
