Mechanically galvanized
bluedog225
Texas
What do folks think of mechanically galvanized fasteners?
I’ve come down on the side of hating them. But I could be encouraged to hate them more. 😂
Was there something wrong with hot dipped? I’ve got an ongoing 40-50 year test running and they seem to be holding up. IMG_9696.jpegIMG_9695.jpeg
Coasterbuilder
Mechanical Galvanized​
Mechanical galvanizing is a process in which parts are tumbled in a drum with chemicals, zinc powder, and glass beads. During the tumbling, the beads cold-weld a uniform coating of the zinc powder onto the surface of the part. Offers superior corrosion resistance, a more uniform coating thickness, and no chance of hydrogen embrittlement as compared to electro-zinc. Post plating dichromate dip can be added for yellow mechanical zinc.
Application: Commonly used on high strength parts where hot dip galvanizing is not possible due to hydrogen embrittlement concerns. Hardened lockwashers are typically are finished with mechanical zinc and yellow dichromate.
PCustoms
VT
@Coasterbuilder thanks.
I dealt with a hydrogen embrittled issue a few years ago, had to dust off my metallurgy knowledge and dig deep to figure out why we kept popping the heads off cap screws. Fun.
PLUM72
One reason to mechanically galvanize a fastener is to reduce the chance of hydrogen embrittlement if that fastener is heat treated. Those Simpson screw anchors have a case harden operation on them. Adds hardness to the threads as it cuts into the concrete. A typical grade 2 hardware store bolt is electro-zinc plated and may have a clear chromate finish over the top. This is that “shiny” silver color you see on this stuff. Use an electro plate zinc on a heat treated fastener, and you need a bake operation to remove any trapped hydrogen. By going to mech zinc, the manufacturer saves a bit on the plating operation by not having the time and expense to do the added bake. Platings and coatings are a true science. Different thicknesses of zinc will give different corrosion protection. A triple mechanical zinc is often equated to hot dipped galvanized.
LopezBart
Lopez Island, WA
Acid etching & then plating traps hydrogen... heating the parts after acid etch drives out the hydrogen again. Typically a problem w/ higher carbon steels.
whateg01
doo dah, kansas, usa
And why do you not like them? Just because they aren't "the way we've always done it"?
bluedog225
Texas
I get the hydrogen embrittlement deal with higher grades.
I think they offer lower/shorter protection. Could be wrong.
Don’t see triple coat mentioned.
I like to build things for the long haul.
bluedog225
Texas
Looks like maybe they can be expected to have a good service life. Would like to see some testing.
mike93lx
Richmond, VA
Maybe reach out to Simpson, they may have some info to share
