Meddings pillar drill - help needed
BiffoBear
Buckinghamshire, UK
Hi everybody. I'm new on here and wished I'd found this site earlier as there's so much good info and helpful people here.
I'm refurbishing a Meddings bench pillar drill which has the markings 9373/LT/MK III on the head casting.
I'm trying to remove the shaft that the operating handle is connected to (labelled A on photo) but not sure how to get it out. I've removed two screws from threaded holes labelled B & C. The part labelled D appears to be plastic and I'm suspicious that it isn't original. Part E is aluminium and I'm reluctant to put too much force on it in case it cracks.
Does anyone have an exploded parts diagram for this drill please. I saw a diagram on here for a MK II version but that is different to my MK III.
Thanks in advance.
Dave455
Sussex, England
You havn't said where you are, but I'm sensing it's the U.K.
First off, try www.lathes.co.uk - despite the name there is info on many machines, and you might be able to get a scan of the manual!
Secondly, try Meddings direct. I know they still offer spares for many machines, even old models, and may be able to provide a diagram!
BiffoBear
Buckinghamshire, UK
Hi Dave455 & thanks for the reply. I'm in Bucks, UK (fixed now in my profile).
I had looked on lathes.co.uk but couldn't find any reference to the LT model.
I'll try contacting Meddings direct.
BiffoBear
Buckinghamshire, UK
I contacted Meddings and a nice man there sent me a copy of the exploded parts diagram. He identified my machine as a Mk2 version of their Driltru type which were in production between 1970 & 1979.
Excellent service from Meddings and with that info., I've now succeeded in removing the shaft.
If anyones interested, here's the parts diagram....
notlob
norcal
So pillar drill = drill press? I was expecting something more like this post drill:
Kryten's spare head
Hi Biffo, is there a chance you've got a bigger version of this diagram? I can't make out some of the writing. I'm just about to start stripping mine down.
MShaw
York, Pa.
Kryten, if you do a "save as" for the file to your computer and then insert it into a program like word or powerpoint you can stretch the image from one corner and make it much larger and more readable.
Kryten's spare head
I did MShaw, but at that point it gets worse because of the low resolution. I asked as it's unusual for a company to archive diagrams like this at a low res. Thought maybe it's been downsized, somewhere along the line, for upload bandwidth purposes.
