Melted Snow In Garage
camaron32
For the past two years I have had to deal with puddles of water in my garage from the melted snow that was tracked in by the cars and the snow blower. I know that the floor has cracks in it, and from where the water pools I can see that the floor nowhere close to level or smooth. Any ideas on how to best deal with this?
ARTEMIS1759
Companies that do mud jacking may be able to raise it a little to a peak so it does not puddle. Not sure on older crete though.
mobetta
twin cities, mn
squeegee and a blower fan out of an old forced air furnace. until you can afford to remove and replace, with drains.
Andamo
Trinity, Florida
I had the same problem as you in my garage. I had a ventless heater in the garage, but that was useless. I ended up putting a vented gas heater along with a ceiling fan. When the cars come in wet and snowy, I just crank the ceiling fan up to high leaving the heater thermostat at 50 degrees. It works well and you're not slopping around in water all the time.
C
camaron32
That would explain why there was a ceiling fan installed in the garage. At first it was a curiosity, but now I understand. Thank you for the help.:)
