Melting letters
JackOfDiamonds
Idaho (USA)
I just spent big on a DeWalt stacking toolbox system. I'd like to mark it clearly as my own so there's no confusion at job sites.
I'll put label tape on it but what I'd like to do is put my initials in the plastic directly by scribing or melting letters. Does anyone have a good method of doing that?
MushCreek
Upstate South Carolina
I would buy a cheap set of letter stamps, make a way to clamp them together, and experiment with heating them enough to mark your initials before using them on your expensive toolbox system. If it was expensive, it's worth trying to make it look good. I used to hand engrave some of my tools, and they always look amateurish. I later engraved them with a pantograph, CNC, or burned them in with an EDM, and they look professional.
Firebrick43
West central Indiana
There are multiple places that can make a “brand” to fit into a soldering iron, any design you want but to mark plastic I would keep it fairly simple and not a lot of flat area
PCustoms
VT
What does tiny engraved/embossed lettering truly accomplish?
If they dump the tools then you might get your cases back (empty).
If it's someone accidentally rolling away with the stack, I think something more obvious is needed. You should be able to get "permanent" outdoor rated stickers made. Yellow with black font would sort of match...
But, doesn't everyone else have Milwaukee anyway? Should eliminate the confusion
GaryM909
Calgary, Alberta, Canada
Paint works pretty good, more and uglier is better. Especially for tools that you can spot from a distance.
I have also used a die grinder with a carbide burr to carve my initials into metal and a Dremel for smaller stuff.
I also had vinyl hardhat stickers made up with my company name. my name, and phone number.
At the time they cost about $100 for two hundred stickers that were 1" x 2".
I stuck them on everything except my hand tools.
It ***** that people have to mark their stuff but I'm sure it's the same everywhere.
dnschmidt
Phoenix, AZ
I’ve tried the melted initials thing and it wasn’t obvious enough for me. So I went caveman with black and/or silver sharpie. That stands out and unless you ground it out leaves an indelible mark.
Cam, that Sharpe can easily be removed with lacquer thinner or Acetone. I would use a Markal paint pen in yellow. https://markal.com/products/paint-riter-rough-surface/097251 It really stands out and is harder to remove once dry.
LXCam
Where the plastic is dead smooth I completely agree D. But on the roughened areas I can’t get the shadow removed even with brake cleaner. You’re right, those paint pens do a good job to, this battery is probably 4-5yrs old and it’s seen some serious use and the yellow all though faded stands out in a crowd.
MushCreek
The uglier they are, the less attractive they will be to thieves. I've heard of making a fake 'repair' with tape on an extension cord to make it less attractive to thieves. When I worked as a tool maker, theft wasn't an issue in the shops I worked in.
rust in the eye
Chicagoland
Wow, what's all that battery power used for? Submarine?
GaryM909
Quite a few years ago I worked in a large fab shop. Sometimes there would be 200 - 300 people working there.
They were always short of air hoses and cutting torch hoses. Night shift would raid the shop for the good ones.
I always had some tape and paint all over mine hoping nobody would steal them.
rust in the eye
Chicagoland
Catalytic converter theft…
We build and retrofit jail / prison controls and camera systems. For some odd reason there’s no receptacles in these joints :dunno:
Oh, you are the free jail door guy.
I'd be all over those like a bum on a bologna sandwich if you were closeby.
bigredcornhead
I tried the melt brand thing as well it work fine, but make sure you get large enough letters it doesnt bleed together. Keep it simple intials or something to that effect. Only other clean way is a lazer etcher i imagine.
Kscardsfan
The Little Apple
Milwaukee Inkzall pens and a particularly hideous pastel or neon shade of pink, purple etc. spray paint seem to work well for most applications.
