Menards Masterforce 6-1/2" track saw?
ishiboo
Oshkosh, WI
Has anyone tried the Masterforce 6-1/2" track saw? I'd like a track saw for cutting OSB/plywood. I don't need a huge expensive thing because if I need a whole lot of accuracy I'll throw it on the table saw, but I don't want a piece of **** either.
I had planned on getting the Makita, but I see Menards now has a 6-1/2" saw that has a full 110" of track. Any experience with it, or one from the same OEM? (powertoolsplus.ca seems to do support, but I'm not sure who makes it and what other brands are identical)
signcrafter
Man that's a great price. The only thing I wouldn't like is the 110" track is 4 pieces. I have the makita and have two 55" tracks to put together to get the 110" for ripping sheets. I have to use a 6' level to make sure the tracks are straight everytime I use them to make a cut. It's an extra step but I don't use them enough to justify the full length 110 track yet, someday. But I'm not sure I would trust 4 pieces connected together to get 110" track. Just seems like too many chances for it to move and also seems like a pain to get all the pieces lined up and straight for each cut. I mean, even for a 4' cut you have to use a straight edge to make sure your two pieces of track are straight. Other then that it seems like a decent deal to get into the track saw game.
I have the makita and love it. Everyone that ever cuts plywood should have a track saw. I waited way way way too long to justify the cost. But once I had it I use it all the time and it is more then justified. I barely use my table saw anymore, mostly for ripping smaller pieces of wood and dados and rabbits and stuff like that. Anything sheet goods is almost all track saw.
And, whatever you end up getting these are the best clamps I have found, https://www.homedepot.com/p/DEWALT-...gclsrc=aw.ds&dclid=CM3giNvV-NgCFUO6TwodYKUF-Q. Not sure if they work on the masterforce but they work on my makita.
I
ishiboo
Oshkosh, WI
I completely agree. But the entire setup is less than just the 110" track from Festool. I figure worst case scenario, I could join all the tracks as one. In theory the guides will keep it straight. I used to have a two-piece straight edge for a regular circular saw, and the piece kept it pretty straight... I can't imagine 4 of them though.
manwithtools
Lebanon, TN
I've got the DeWalt with the one piece tracks. I've had two piece saw guides in the past and could never keep them straight. The one piece tracks on the other hand work like a table saw in terms of straightness. It's money well spent in my experience. I think I paid a little under $600 for the DeWalt about 6 years ago with the long and short tracks.
I built a designated set of sawhorses and support frame for it, and now I'll use it for everything from case work to roofing sheathing.
No longer own a table saw. Might get one again someday, but if I do, it will be a a sliding table version.
signcrafter
I have to use a straight edge for every single cut for my Makita when I join the two 55" tracks. When I first started using it I was ripping 6" wide strips off a 8 foot long sheet of plywood and couldn't figure out why they were different. The connectors don't hold it straight. Whenever I use mine I have one of my long levels handy to always straighten it up. I mark both ends and then line the tracks up and clamp the ends down. Then grab the level and put it up against the tracks to straighten them up. I wouldn't want to do the 4 piece tracks like that.
dragginbalz
Illinois
I just found out that Menards had this and picked one up last weekend. With the 11% rebate it ends up being about $177, which sounded too good to at least try it! I hear all the stories about setting up multiple tracks and I was a bit worried, but a straight edge and first try I got all four tracks set up to as good of tolerances that I would expect! I am still a table saw guy so I did just use for rough cutting, but after a few sample cuts on melamine coated pb, it cut very accurate! without a scoring cut, it did have chip out with the 40t blade it comes with, but I assume a slightly better blade will help. I did not hook up the dust collection yet, but the shroud and track kept me from getting pelted in the face with melamine chunks like a rough cut with a circular saw usually does. I have a hose now and will try it this weekend with the dust collection hooked up.
I tried a scoring cut and then a full cut and I was VERY impressed with the quality of the cut! Very few chips, straight, square cut. I was using the provided clamps to hold the track since the melamine coating is so slick and that is where I encountered my first issue.
While ripping the full sheet, no problems using the clamps and track. When I went to cross cut with the full track, I realized quickly with the track connectors in place, you can't just slide the clamps to wherever you want them. I didn't want to keep disconnecting and reconnecting the tracks, so I just slid the one side of the track to the end of the workpiece so that I could use one clamp and then on the side I started the cut, I was just careful so the track didn't slip, it worked great.
I did purchase a Makita 55" track this week and after a bit of filing and sanding on the shoe of the saw, I was able to confirm it would work. I am going to now rip off the small lip on the Makita track to get a little more clearances. I can explain this better and maybe take some pics if anyone is interested.
This saw does not seem to be the same as the Grizzly/Shop fox/Scheppach that has been around for years. Many complained about the spring tension being too tough on those as well as the track pads being too close together making the saw tippy. This saw the tension feels right and although slightly annoying with the small tracks, they were surprisingly straight and sturdy. The saw is easy to get in with no wobble.
I was contemplating a Festool for years and was just about ready to pull the trigger on the Makita. I was fully expecting to use this, like the benefits of the track/plunge saw BUT not like the quality, return it to Menards and buy the Makita or Festool, but after using it, I felt this would work perfect for my work habits, speed up the breakdown time and possibly give me acceptable cuts without running through the table saw so I committed to keeping it. All for under half the price of the Makita with a 55" track.
jonshonda
Wisconsin
Anyone else using these yet? I would really like a track saw for processing sheet goods, but really have a hard time justifying the price of a Bosch or Makita setup.
mday1
I know this is an old thread, but I bought one of these track saws and was disappointed. Mainly because of the 4 small tracks that need to be ganged together to make 100”. On top of the difficulty in making them straight, they are only connected by one linking bar so they are very floppy. And they don’t line up very well so the rectangular slot the saw rides in will get hung up if they aren’t perfectly aligned. Lastly, when tightening the linking bars the set screws go against the rail the saw slides on and dimples the aluminum VERY easily. Simply a bad design all around of the track which is a bummer. The saw itself was okay.
I returned it it and got the newer version of the wen and (2) 55” wen tracks. Basically the same price and the tracks are MUCH better and the saw is a little nicer too.
mday1
No problem. I really wanted to like the track saw, but the rails were just trash and poorly engineered.
