Menards Ultradeck Fusion Composite Decking Experience
Newell33
Midwest
Hi Guys
I thought I'd share my experience with the Menards Ultradeck Fusion composite decking product. I had some vacation time last week and decided that I needed to replace the boards on my 10'x 18' deck next to the house. I checked online inventory for Lowe's, Home Depot, and Menards to see what was available. Menards was the only store that actually had everything in stock that I needed in a product that's not designed to fade quickly over time. I used their deck configurator online, and it spit out a total of 21 20-foot boards that I could cut into 10 foot lengths, and a single 12 foot board to ensure coverage.
The Ultradeck Fusion product uses a T-Clip hidden fastener to hold the boards down. Once the first board is installed with regular style screws down the side of the plank, the T-Clips are installed on the other side. Then the theory is that the next board can be hammered into place with a rubber mallet under the side of each clip. Their configurator recommended 5 bags of 100 fasteners for the project. The screws that come with the T-Clips use a #1 square drive head, and each bag of fasteners comes with 2 square driving bits.
After loading the boards and arriving home, the fun began. After installing the first plank, right away I noticed that the screws that were included with the T-Clip fasteners were probably the softest and worst screws that I've used with any product. Even with brand new bits (I tried Milwaukee and Bosch bits too), the screw heads would strip almost immediately. The entire first bag of screws seemed to have been made of the cheapest grade of metal that could have been found. Finally I got to the second bag which seemed to have a mixture of some decent screws along with some of the same quality of the first bag. The remaining bags also seemed to be a mix of both good and bad.
The next issue that I ran into was the installation of the boards under the T-Clips. In order for the next board to fit simply using a rubber mallet, the T-Clip would have to be left very loose. I noticed in the videos that I watched that some T-Clips have little fins on them, and some don't. Mine had the fins. I would assume I received the latest version of the clips. If I were to snug the clips to a point where I thought the board was secure as shown in the installation videos, then the next board simply wouldn’t go into place far enough with a rubber mallet. In my case my original deck and framing was built over dirt, so I devised a plan to stick a piece of flat steel in between the slats of the previous boards down into the dirt a ways, and then use a squeeze clamp from the flat steel to the board I was trying to install. With the squeeze clamp as tight as I could get it, I could then use the mallet to hit the next board into place. Of course, this method took a lot of time as the steel and clamp had to be repositioned for just about every other clip. The T-Clip and screw issues pretty much doubled the time that it took to complete the project. I did reach out to Menards in regards to the screws. One of their buyers emailed back right away and stated that they were looking into the issues, and that they took them very seriously. He offered to swap the screws out for more, or to return them. At first I was throwing them away, but then I started saving the junk ones. I probably have around 40 of them that I held onto in case they wanted to analyze them. Having dealt with Menards in the past, I decided against trying to return 40 or so bad screws from a 100 count bag. I’m sure they would have laughed me out of the store.
A few days after the purchase I received a Menards 4th of July promotional email stating that the Ultradeck Fusion product was now on sale at $2.19 per linear foot. Since I had paid $2.59 per linear foot a few days earlier, and I still had one unopened bag of screws and T-Clips to return, I decided to make the drive back to Menards to return the unopened screws and hopefully receive a refund for the difference in the price for the boards. The ad states that the Fusion product in Driftwood Gray and Coastal Cedar are on sale (I purchased Coastal Cedar as that’s what they had on hand). In a bullet point it states 1” x 5-3/16” x 8’, 12’ and 16’. Then in the heading of the ad it states 20’ ALSO AVAILABLE. It makes no mention, however, of a higher price for the 20 foot boards. Of course, I was informed right away that the 20 foot boards that I purchased were not a part of the $2.19 per linear foot sale. The manager confirmed. Now keep in mind that I haven’t purchased a lot of 20 foot boards in my life, but when I saw the for sale ad I had no reason to believe that the 20 footers would be more per foot. I understand that there may be additional handling costs to get this product to Menards, but I loaded the boards on my trailer myself. Looking at some of the other wooden boards in the ad I see that 20 footers are listed at a higher cost per foot, but the Ultradeck Fusion ad makes no mention of a higher cost, and I didn't pay attention to the ads for the other products when I first looked. The only mention of additional packaging / handling costs is in regards to the Rosewood and Walnut colors which are special order at all locations. The product I purchased was in stock. After they refused to discount I decided that I’d cancel the order for the cladding that I had placed at the time I picked up the boards. Although it would have looked nice, I really didn’t need it, and after the screw, clip, and pricing issues I was ready to be done with Menards.
When searching for reviews on this product I didn’t really see a lot online. The boards themselves aren’t bad, and seem like they’ll be durable. My only complaint is they are a bit slick when wet. I think this is probably true of a lot of composite decking. The biggest issues, however, are the screws and clips. The screws are almost unusable. They either need to take another look at their metallurgy, go to a Torx head design, or both. If the screws and clips were updated, I’d say that I could recommend the product. Based on what I received and installed, there’s no way I’d use the product again or recommend it. As for Menards, well, I’ve always liked shopping there, but whether I should be or not I’m still upset about them not honoring the price on the 20 foot boards. I’ll likely still shop there once I get over it, but I certainly won’t be making any large purchases there unless I have no other options. Based on my experience, if you're planning a deck project, you might keep the Ultradeck screw and clip information in mind when making your decision.
callcoy
Nashville
I feel your pain and am sorry for the problems, I thought I would share a totally different problem but one like you I believe everyone on here should be made aware.
We have a problem with a refrigerator that we bought from Sears inline in the last few weeks. I thought that we could trust the "New" Sears with a simple purchase. Unfortunately while we were in Italy and Greece our electric Co. shut off our power, for 20 days the entire house was without power including both 4 year old refrigerators. That situation is another matter that will be taken care of.
We lost 140 pounds of meat alone, had excessive stench to deal with and buckled floors and have had out of town guests for the entire time we have been back. We really needed a second refer, so in the mean time we decided in order to obtain a some what special unit quickly we would try Sears.
Big mistake the first unit wouldn't come down to temperature on the refer side, ordered another unit. This was installed but the one of the front doors was dented when I inspected it. So another was ordered, but we were held captive in our own home by missed appointments, but we paid for a product, so another unit was sent and installed.
This unit doesn't make ice or deliver water had an alarm that went off every 90 seconds until I figured out how to disconnect the alarm. Unfortunately this condition did not occur while the installers were here but started right after the refer door fell off. While waiting for Sears to send out a repairman we noticed that the refer side is freezing it's contents. Contacting Sears for service was a 3 hour ordeal and when someone came out he was 3 hours late and he not really speak English neither did the driver of the truck who used a hand held translator as he could not speak English at all. We wonder how he even obtained a drivers licence.
At any rate we are over 8 days trying to get unit #3 repaired or replaced but have not heard back from Sears. I wonder if we will ever see quality service from some of our American Companies.
johnnparry55
Wilmington
Hi Guys
Check refrigerator.
D45
NW INDIANA
I considered the Menards line of composite decking a few years ago....because of the price and close availability
However, I went with Azek and Camo hidden fasteners because my local lumber yard had a promo 0% for 4 years
$56 a month for 4 years. The stuff is pricey
I bought 20' long boards, for my 12 x 20 patio. Its nice not having seams or visible screw holes
K'ledgeBldr
Johns Creek, GA
When I read "composite", I knew I wouldn't need to read anymore!
That S#!T isn't worth a damn! Enough said. I do not, and will not spec composite on any deck. Anyone that has asked me about using it- It's simple, I don't do composite-period! If they want something other than wood, I will highly recommend PVC.
purplezr2
Central MN
OP the ad clear states that 8', 12' and 16' foot boards are at the listed price, it doesn't say that 20's are include with the sale price, that's how I would read it, but I have been looking at Menards flyers for the last 20 years, and even worked for them for a short period in college.
I have a three year old trex deck, great material, easy to work with. Hidden fasteners work as advertised. Deck is not slippery when wet or icy that I have noticed. Have the railing system, after reading the direction it was easy to install(My now ex-gf did most of the railing install actually and she is not a carpenter by any means).
I had one board with a manufactering flaw. I reported it on Monday direct to trex and by Thursday there was a check in the mail.
bdbecker
Iowa
OP - thank you for your review. I believe I read your post last spring when I was considered using the same product for my deck, but never commented in the thread.
Every item I have ever purchased from Menard's has arrived in perfect shape, boxed correctly. I'm surprised to read the negative menards reviews.
I've also had generally good luck with Menards, but I think they face the same challenges as any of the box stores in that some products can be hit-or-miss. If you have the option, I think its always good to shop around between different places to find the best combination of cost and quality.
When I ordered material to redo my deck last year, Menards price for cedar decking was the best out of the places I got quotes from. While a few boards had issues, it wasn't anything I couldn't work around and the overall quality of what I received was better than I expected. I don't think I could have done much better if I hand picked the boards at the store.
When I was building a fence around my stairwell to match the new deck, I bought the post brackets and cedar from Menards, but went to Home Depot for most of the PT materials as the quality was significantly better than what I found at Menards, and the pricing was the same, if not better on a few of the items.
finn
The UP, God's country
Old thread, but I installed Menards decking, about 500 sf, in 2003. That’s almost 18 years, and it still looks pretty good.
My wife power washes it every few years, but otherwise it’s been maintenance free.
Shiftless
East Bay SFO
Having heard all the horror stories of early Trex and other brands of composite decking, I went with Moisture Shield which was not carried by anyone except pro grade lumberyards. I also heard of problems with the invisible fasteners failing so I went with screwing them down from the top with torx drive 316 grade stainless steel screws.
No problems whatsoever after almost 20 years. Minimal fade even though the deck sees direct sun all day.
Like all composite decks though, on sunny days, the surface feels much too hot to walk on with bare feet. Just wear shoes… problem solved. 😎
rande
The Trex dealers I consulted when I rebuilt my deck years ago aren't in business anymore. I didn't want to burn my dogs feet so I went with wood.
