Merry Floodmas
38 Dodge Coupe
Delaware Ohio
You know- it may have been a good thing that the breaker popped. At least now you can take care of it under your terms and not when it has taken out the whole panel in the middle of the night!. Good luck-
nadogail
Coronado, CA
Looks like a job for your heat gun and a liberal application of Water Displacing Compound number 40 (Commonly referred to as WD-40). Get it dried out, track down the leak, seal it up and pat yourself on the back.
frankush
IL
The water damage is not something that happened overnight. It looks like the condition has been around for some time. I would find out how it's coming in and seal it off. I would also replace the panel. The exposed copper wire, if oxidized, should be stripped back and could then be terminated on the breakers.
M
MichaelBikel
CT
Yeah I guess I got lucky that the breaker tripped otherwise I would have never found it. I guess its been happening every time we get heavy rain. This is a cutler/hammer box that I will be replacing along with the box outside, this may also be the time for me to install some shop-lights and a dedicated circuit(s) as well.
rburke65
Canfield, Ohio
Might want to check the "weather head" at the top of the service entrance cable or atop of the meter box where the cable enters the top of the meter box.....if this applies. A photo of your electrical service might help. Good luck.
M
MichaelBikel
CT
I checked the service box and the problem area seemed to be next in line in the signal flow. Its all coming out soon, the box is rusty/corroded and I think its just time for a new one.
davo727
Good to see you plan on replacing the panel and those old style crappy breakers.
M
MichaelBikel
CT
Just out of curiosity, what is wrong with that style breaker?
From what I know (which is limited) C/H discontinued them I believe. I am told you can get compatible breakers but for some reason it is better to replace. (at least in my situation it makes sense) I am curious to hear from someone who has experience...
ishiboo
Oshkosh, WI
Looks like a Cutler Hammer CH, still their top of the line residential breaker? Not discontinued.
M
MichaelBikel
CT
I was told that they didn't make these switches anymore, I didn't actually look around yet but now that you mention it I think i'll look
redmondjp
Redmond, WA
They are still in production, google 'Eaton CH'. Home Depot carries them.
But I would replace that entire panel ASAP, if the main bus bars look like I think they do.
