Xkylescorex
- Joined
- Jan 10, 2016
- Messages
- 160
Ok Im installing a used mini split. I made new flares, did a nitrogen pressure test and then did a vacuum with my micron gauge. Everything looked good. Next step is let refrigerent out of the condensor.This is where it went wrong.
I opened the manifolds and let the refrigerant into the lines. U hqd a cheao $12 ebay schrader valve core remover. Then I went to put my schrader valve back in. Not sure what happened but my cheap ebay valve core remover started speewing refrigerant from its seal. It was leaking out of the valve handle. I guess a seal blew. I couldnt get the scgrader valve to seat. Lost all my pressure. I have exrra refrigerant bjt not sure what to do now. Can I pull a vacuum with the schrader valve in? Then add back my refrigerant? Im assuming I lost all my refrigerant. What should my next steps be?
