Vinko
UPDATE: Metabo Vac ASR 35 HEPA via CPO (Hidden Damage now apparent!)
[NOTE: I've been a member here for almost 8 years and I hope I've given no reason for those to think I'm dishonest at all. Below is a damaged vac I received from Metabo -- at first glance it was OK until I went to start to use it -- moral of story (and I should know this by now): thoroughly inspect at time of delivery. Sometimes if you've got so many jobs that's hard to do). Hopefully CPO will make good!]
Picked up a Metabo ASR 35 with HEPA filtration from Metabo CPO (via their amazon store). Like the last thing I got from Metabo CPO it came a little thrashed. Or at least I've got a broken plastic piece (pictured) though I can't tell from where on the unit it is from or if it's even from that unit. [Note: I thought it could be just a "phantom" piece from some die-cast material!]
I'll update this thread as I use the vacuum for various kinds of work. We've got Metabo grinders, sanders and drills in our shop and work with wood and metal. Mainly will use for maintenance projects and improvements.
I looked at the Fein and the Festool and decided to go the Metabo. A lot of discussions on the 'net about these units and who makes for whom.
Apparently, I can use Bosch vac (depending upon the year/model) accessories for the Metabo. If anyone has a good inexpensive source for different fittings + the bags, please share.
Don't know if all my Metabo tools are compatible with the connectors, but I'll find out.
