I have a metal arch garage, 20 by 20 ft. 12 ft high. Built into an older square 16 by 26 ft garage. I needed the space so I built one end of the arch metal garage into the older wood frame garage. turned out pretty good. But I should have gone at least wider. 10 ft wider. I am pretty satisfied with the size since adding on. But I learned real quick that bigger is better. 30 by 30 would have been better. But I can either take it apart and put up a bigger garage or add to the side if it is possible. Could add to the front, but one of my neighbors doesn't want it blocking her view. It can be done I am sure. I have a lot of work in the garage now, taking it apart would be a lot of work since I have already modified it, the metal garage. Was thinking of building onto the side of the metal arch by leaving two ends on, which are 2 ft wide each, to support it. That would leave 16 ft width I could add on . I would have to take the 2 ft sections off in the middle of the building, leaving 16 ft length. Was going to extend it out around 5 to 8 ft on the side. It would be kind of like putting in an entrance door only wider. Any ideas. Thanks!
