Metal bandsaw enco vs doall
Jeeper75
Dayton, Ohio
Hey everyone. So been keeping my eyes open for a bandsaw for the garage to cut steel. These two have popped up locally. First is a 14" enco that's been converted to 110v and has adjustable speed. The blade welder doesn't work which doesn't concern me.
Next one is a 16" doall. Still 240v 3 phase. It would need converted to single phase 240 or if possible to make it easier where I would put it to be 110v if that's even possible. Looks like the motor would be fairly easy to swap since it looks like the variable drive is like a couple conical cones or something.
Obviously I like the doall being USA made and well made but the enco is ready to rock. I'm just a hobby user who would use this maybe a few times a month maybe depending on my project
Any opinions or advice converting to single phase. Not really up on doing vfd etc. when it comes to that my mind melts just thinking.
Screenshot_20251102-222258.pngScreenshot_20251102-222337~2.jpgScreenshot_20251102-222353~2.jpg
Firebrick43
West central Indiana
A metal cutting band saw running on 110v is going to be anemic and slow as hell.
Get the do all and put a vfd on it. Its not that hard.
Hell I have 2.5 hp on my 14" wood band saw and its not a hot rod by any means.
tool_scrounge
Southern California
Get a VFD and go with the Do-All and the existing motor. Note that the reeves belt drive is tensioned using the weight of the motor. The ones I have seen use a very heavy motor for the proper preload. Swapping a lower weight 1 phase motor will have issues unless you compensate for it.
Jswain
Calgary, AB
I used to think the same on VFD and bypassed all the 3ph equipment.
I just brought home my first 3ph lathe last week. Did some research. Bought an Amazon 3hp VFD (1.5hp lathe) and had it wired / programmed in maybe 2 hrs tops. Super simple.
I will happily buy 3ph equipment in the future.
GeoBruin
There is so much info out there in such easily digestible formats (think step by step video tutorials) on wiring VFDs, it really shoudnt scare you.
Both saws look nice but those DoAlls are sure sweet.
Firebrick43
Steve from Socal
Hutchinson Ks.
The old DoAll is a much heavier frame that translates to a better cut. The saw motor is three phase, the welder is single phase. An inexpensive VFD is all you need.
cannuck
Rural SK
Add another vote for the DoAll. Easier to support, unquestionable quality. I have one small bandsaw set up for quick tilt to use a small table for vertical cuts, and realized I use if far more than my big horizontal, so a DoAll came home one day. The variable speed, ***********, tilt table, feed slot all make it a far better solution. I stayed 3 phase since the saw will sit right beside my Bridgeport clone and can use same rotary converter.
(on edit) one thing to consider: once you get a really good vertical you might find yourself feeding really big stuff or a long cut or just a wee nip, so think about putting it on locking wheels. I even have an 85 ton punch on a swivel table for that reason. Few shops can swing a 20' anything around a big tool.
slowtwitch73
Hellgate
That Doall looks very tidy and unmolested. Interesting the blade welder is mounted off to the side instead of to the rt inside the cover plate.
Better support for the Doall, better resale.
txvwnut
Bedford, Texas
The ENCO would probably serve you well for a hobbyist setting but I'd get the DoAll. The only issue I could see with the DoAll is if the blade welder is three phase, I don't think they were, it might not like being on a VFD.
slowtwitch73
Hellgate
They are 110..
tarbellb
Oregon
Agreed the Do All is the better choice but that Enco isn't a bad machine either
I've done 2 VFD conversions without knowing much about the process, it's doable, but ...
that motor is super accessible and likely a easy swap. Gives you plenty of choices to power it.
