metal building - garage door VS roll up - depth
MVWSR
backyard
Can I get some help on the site , I need some pics of the measured opening (depth) for a garage panel door on a single base rail vs depth of a rollup on a double base rail
I'm trying to get total finished depth of these two
racecougar
Missouri
Are you asking how far into the room a sectional door goes vs a rollup door? If so, that is going to depend on the door height, track height, etc. (more information is needed from you).
MVWSR
backyard
No, i need a real measurement of the wall width + door at the jamp.
Ideally both a double rail + roll up & single rail + panel door
racecougar
Missouri
You might need to post photos of what you're after. I can't fathom a need for a double rail with a roll up door. Are you referring to a sectional door as a panel door? Won't the wall thickness vary based upon framing (2x4 vs 2x6 framing, for instance)?
Codyboy
S.E. TEXAS
My jambs are 8" plus the 1 1/2" deep ledge the metal siding sits in.
Guide rails are 2" deep into the building and 4" wide. The doors are 2500 series Janus roll ups.
The recess the door sits in is about 13" from outer edge of slab.
Not sure what single or double rail means.
ETA forgot the pics...
MVWSR
backyard
Yes this is exactly what im asking . My ask regarding single or double rails is my bad, My build is a steel tube building
