Deude_Mann
So I am budgeting for retrofit installation of vinyl backed fiberglass insulation in a 30x40x12 metal building and am weighing the cost of hire vs DIY. The insulation and installation would be this style here, wide cut battens held in place with banding, roof and walls. Like this...
https://www.metalbuildinginsulation.com/insulation-ceilings.html
I am trying to get an idea of the DIY man hours required for this from those who have DIYed it themselves. I am at a skill level where I can handle the job, and will have the requisite lifting equipment like a scissor lift. I'll have about 4 hours a day to do the job.
Diving a little deeper here:
The building is new and will be sprayed, walls and ceiling, with 1" of closed cell foam insulation, pro installed. This will seal up the building and act as the vapor barrier.
So there are at least two basic ways to go here for additional insulation that I am considering. One is to have an additional 1" of closed cell foam sprayed in for a total of 2", and then coat that with a fire resistant coating. Two is to just use 1" of spray foam to seal the building and then go with another system over that like the batten/banding system. I am trying to avoid the cost and labor of having to frame and drywall or otherwise add an additional layer of heavy covering. For this workshop I don't need to go to that extent.
I suspect either will be about the same cost if I consider my time for batten insulation or pay the installers to do it. The main benefit of the batten insulation would be the higher cumulative R-value, the inherent fire protection, and the better finished appearance.
I am in Central Texas and so the building will be air-conditioned, most likely with a mini-split.
I bring all this up in case someone has another suggestion.
