Bib Overalls
Hard to believe I put up my shop building over 12 years ago. When I built I used a package from Adam's Truss in Gentry, Arkansas. The package consisted of the five steel trusses, 1" thick AgBoard insulation, the tin, and all necessary fasteners. I sourced the wood for the girts and purlins locall and contracted the concrete work.
It is a nice sized, well constructed building but it is hot in the summer and cold in the winter. At 70, I just could not stand to be out in it working.
So, a couple of years ago I installed a 3.5 ton package heat pump. At the time I also insulated and finished the stud wall on the back, stick framed gable wall.
It was not long (1 electric billing cycle) before I knew that the building needed an insulation upgrade. I started with the ceiling and had 3 inches of foam sprayed. Made a big improvement but there was still more to do; 2 side walls and the stick framed front gable wall.
I had a plan/idea for the work but it called for 1.5" thick foam board and that stuff is expensive.
Then, a couple of months ago, I saw an ad on Craigslist for used foam boards measuring 4'x16'x1.5". Perfect and the price was right, $10 aboard. I bought 25.
Shop Remodel 092 by Bib Overalls, on Flickr
This is what I started with. Steel vertical posts and 2"x4" girts. The white stuff is 1" thick AgBoard rated 5R.
Shop Remodel 094 by Bib Overalls, on Flickr
I started by ripping 2"x6"x10' material in two. This became wall strapping. I attached it with deck screws.
Shop Remodel 095 by Bib Overalls, on Flickr
With the strapping in place I cut some of the foam material into strips.
Shop Remodel 096 by Bib Overalls, on Flickr
The strips were then cut and fitted behind the strapping.
Shop Remodel 097 by Bib Overalls, on Flickr
I used different strip widths depending on the width of the strapping and the posts. I wanted the foam to extend about 2" into the bay so the top layer of foam would overlap. This creates a void with little or no air movement. Contained air is a good insulator.
Shop Remodel 098 by Bib Overalls, on Flickr
The foam boards were cut to width and length using a table saw and a circular saw. In some cases I needed to adjust the strapping and the deck screws made this easy to do.
Shop Remodel 099 by Bib Overalls, on Flickr
The walls were finished with 7/16" OSB. 2 full and one ripped sheet went up first.
Shop Remodel 100 by Bib Overalls, on Flickr
The filler panels were scribed and fitted. Next step paint. The OSB will get 2 coats of Kilz oil based primer followed by grey and white latex. With the exception of the points where the girts and straps cross the walls have at least 2.5" of foam insulation. That works out to 12.5R. Better than a lot of houses around here.
Shop Remodel 101 by Bib Overalls, on Flickr
Shop Remodel 092 by Bib Overalls, on FlickrThis is what I started with. Steel vertical posts and 2"x4" girts. The white stuff is 1" thick AgBoard rated 5R.
Shop Remodel 094 by Bib Overalls, on FlickrI started by ripping 2"x6"x10' material in two. This became wall strapping. I attached it with deck screws.
Shop Remodel 095 by Bib Overalls, on FlickrWith the strapping in place I cut some of the foam material into strips.
Shop Remodel 096 by Bib Overalls, on FlickrThe strips were then cut and fitted behind the strapping.
Shop Remodel 097 by Bib Overalls, on FlickrI used different strip widths depending on the width of the strapping and the posts. I wanted the foam to extend about 2" into the bay so the top layer of foam would overlap. This creates a void with little or no air movement. Contained air is a good insulator.
Shop Remodel 098 by Bib Overalls, on FlickrThe foam boards were cut to width and length using a table saw and a circular saw. In some cases I needed to adjust the strapping and the deck screws made this easy to do.
Shop Remodel 099 by Bib Overalls, on FlickrThe walls were finished with 7/16" OSB. 2 full and one ripped sheet went up first.
Shop Remodel 100 by Bib Overalls, on FlickrThe filler panels were scribed and fitted. Next step paint. The OSB will get 2 coats of Kilz oil based primer followed by grey and white latex. With the exception of the points where the girts and straps cross the walls have at least 2.5" of foam insulation. That works out to 12.5R. Better than a lot of houses around here.
