crooney1189
Looking to see if anyone has any experience with any of the following builders. How did your build go with them?
Carolina Carports Inc. - Dobson, NC
Real Steel Metal Buildings - Valdosta, GA
Tubular Building Systems LLC - Lake City, FL
Steel Buildings & Structures Inc. - Mount Airy, NC
I'm located in West Central FL, about an hour above Tampa. I've been receiving quotes for a 30'x50'x14' metal building from 4 different vendors, and these are the manufacturers they use.
I've attached the 2 different proposed building layouts (will only be ordering one building, depending on how I end up laying out the yard) as well as the backyard layouts if anyone is interested and would like to offer their thoughts. Maybe you're seeing something I'm not, or have some advice of their own to offer up?
I will be using the building for typical garage and hobby mechanic use. The biggest vehicle in the fleet at the moment is my '18 crew cab GMC and that's what I'm planning the space around, as in if that fits everything else should too. I'll eventually have a mobile 4 post lift (Wildfire XLT probably). The plan is also to insulate and air condition the building as well if I can squeeze it all into the budget.
Appreciate your time and input!
