Metal Building Screw Suggestions
cjbarnwell
For a metal building, what type of screws are recommended for mounting to the 2" ribs? I would like to mount an electrical panel, TV and other items via unistrut.
Thanks
inphx
Phoenix/Scottsdale AZ
Others will chime in about mounting to the sheet metal.. but inside i had unistrut down to the floor to support weight and on the upper end with pass through bolts i had some unistrut outside to allow me to use bolts binding the inside/outside unistrut instead of sheet metal screws. Later that technique was reversed for an outside solar cutoff panel needed.
PCustoms
VT
Thanks
None.
Mounting to the ribs won't be structural.
C
cjbarnwell
Apologies I may have misspoke, I was wanting to mount unistut to the ribs of the building, not the sheet metal.
