Metal Building Venting
bfr57
I have a 32' x 85' x 17'(h) metal building in southern AZ. It has insulation that's between the panels and girts/purlins. 2 14' doors. In the summer, it gets really hot with our AZ temps of 110, and takes a long time to cool down. I neglected to install any type of roof venting and wonder if it would help to cool it off quicker? I've seen vents that are 10' in length that can be opened/closed for natural convection. Or would exhaust fans be better? I've also had the thought of installing heavy duty plastic vertical curtains and HVACing a bay, but that's a totally different conversation.
LiketoFix
OHIO
Besides adding venting and trying to let some of the Hotter trapped air at the ceiling out, I think I would look into possibly adding some Solar powered Ceiling fans to keep the air moving inside of the Building! With all that Sunshine at your disposal it's kind of a no brainier to me. In my Attached Garage home, 50' x 36', in Ohio, as it heats up in the summer I have a wall mounted exhaust fan on the last high bay nearer the ceiling to remove stagnant hot air, fumes, weld smoke, etc..............It works well and with the summer warmth at times I'll kick on the two high mounted fans just to create a cross breeze. I do have A/C in the Garage as needed, I just don't like elevating the Electric Bill!
IMHO.
LtF
jack stand
Lakes Region Maine
Conventional roof ventilation depends on 2 things, intake venting (low) normally at the soffits, and exhaust (high) at the ridge or very close to it.
This is usually full time natural convection with no user input.
A good alternative is big louvers high in each gable end.
bb29510
i got a wall fan 24" that will exhause the whole building in about two minutes. i got it for welding but it will cool a building down in about two minutes
billconner
Thousand Islands NYS
I like this approach but it's only going to be as cool as the outside, which ar 104 isn't too cool IMHO. But hey, I lived living in artic circle and -40 for all of January.
bfr57
billconner: See my pic. The insulation is rolled on before the sheeting is installed.
bb29510: I've thought of exhaust fans at each end. I have enough space between the 2 upper girts (right above the Texaco sign). How big is your building? That might be the way to go as I also do welding, painting, exhaust fumes, and do powder coating that sometimes creates smoke when I pre-bake parts; fans would help get that stuff out quickly. I have 2 14' rollup doors that would give plenty of intake air. If fans cool things down quickly, that's also a plus when the sun goes down and cools off; my garage will still be 110 inside and 90 outside!
bfr57
bb29510: Another question; how noisy are these fans and do they have automatic louvers? (Guess that's 2 questions.....)
billconner
Struggling to see how ventilation will cool it below exterior temp, but no doubt it gets hotter in loft area than exterior, so maybe that's good enough?
bfr57
billconner: totally agree with you. We have days that'll reach 110+ and then cool down into the 90s once the sun goes down but my shop can't cool off quick enough having all of that trapped air.
dcg9381
Austin, TX
Push/pull fans with louvers as high up on the building ends as you can get them. Neighbor has a 4k shop, no AC, this is how he does it.
I have an "attic fan" in our 3-car garage. There is an apartment over the garage. I have the fan setup on a thermostat, so if I park cars in there (heat soak), the fan comes on and vents the garage to the outside.
bb29510
yes on louvers, turn the fan on and they open, loud, not really bad but you know its on, you can still carry a conversation but its like a barrel fan on high
