cthulu
Been reading up on insulating metal buildings and I want to see what everyone thinks.
I live in the pacific northwest, rainy half the year 35F-85F variance.
Goal is to prevent condensation on the metal wall and insulate the building enough so that I can use an electric heat source, gas or wood burning is not an option.
I have 8x8 beams connected by 2x6 and 2x4 horizontal supports that the exterior metal sheeting is screwed into. I found a good deal on 2.5in thick EPS with foil backing and plan to glue/screw it onto the horizontal wooden cross beams with the foil side facing the exterior towards the air gap and metal exterior wall. From there I'll attach 1in fir strips to the horizontal cross beams through the foam and finally a .5in OSB from the 8x8 to the fir strips as they should be level.
I'm worried about which way the foil should face as from what I've read it acts as a vapor barrier. My diagram has it facing outside but with me heating the inside of the garage wouldn't that cause moisture to form in the EPS? Is a layer of vapor barrier (vinyl sheeting etc) needed for this?
Thanks guys, this site is always helpful.
I attached pictures of my diagram and the wall. Let me know if you have questions.
