Metal Capped Screwdrivers
billymade
New Mexico
Wiha has some nice looking ones too; the handle caps are made of steell! http://www.wihatools.com/indexes/indx_MicroFinish.htm
Fedwrench
Valley of the sun
Stanley makes a nice two piece demo screwdriver set. They also come in others sizes and can take a beating. The set is less than $20 and is handy because it gives you dedicated beaters while preserving your other screwdrivers. One thing to remember is that the metal striking cap affects the overall balance of the screwdriver and it may not be as comfortable to use as a regular screwdriver.
http://www.stanleytools.com/default.asp?TYPE=CATEGORY&CATEGORY=DEMOLITION+DRIVERS
ImportTuner
I'm in need of some screwdrivers that can take a beating .. I currently looking at these ....
http://www.nationaltoolwarehouse.co...F0C-7D9E3961DA6B}/prodid.22104/qx/product.htm
http://www.amazon.com/exec/obidos/t...t_shr?_encoding=UTF8&m=ATVPDKIKX0DER&v=glance
Can anybody please share some opinons or probably links for better choices
Thanks
I have the Cats Paw set which is made by Mayhew ... very durable, but the soft grip is a pain in the **** to clean; same applies to the Cats Paw pry bars .. that why I like the Snap On/Williams hard plastic screwdrivers ...
J
JayL
Manila, Philippines
Thanks for the feedbacks. I am actually more concerned about the durability because these will be used in a wrecked cars yard where we need to dismantle any parts we want to buy. If the Cat Paws can hold their tips then I don't mind the extra effort needed to clean these after use.
Detroit Diesel Man
MN
I'm confused, why beat on a screwdriver:confused:
I am too...why not just use a chisel..I'd think that beating on the end of a "screwdriver" would void any warranty for the tip when it snaps off as "screwdrivers" arent ment to be used as chisels.
I'd ask about warranty before purchasing..specifically if the tip snaps off wich I'd guess it will.
DDM
J
JayL
Manila, Philippines
Actually it might or might not be needed. However the yard is far from us and we don't want go there to buy surplus parts and be unprepared in case we need to do something like this in order to dismantle any spares we need.
Good point , we'll bring chisels too.
nissan_crawler
Wichita, KS
Judging by the way I have seen people use them, they either use them as an impact screwdriver, or deal with a lot of SEVERELY (can't tell if it is standard or phillips) rusted screws.
If the screw head is rusted out, beating it won't do any good. If it's just blocking the screwdriver tip, smart people clean it out with a pick, then go back to the screwdriver.
If you need an impact screwdriver, get an impact screwdriver. They work 10x as good, and are built for it.
Again, i see no need to be beating a screwdriver.
Stuey
28m above sea level
I like the Stanley 2 piece set from Lowes - $10 for great tools. NOTE: the drvers in an enclosed cardboard and plastic package are made in England. The drivers which are held by the shafts allowing the handles to dangle somewhat freely are made in Taiwan or similar.
eschoendorff
Yup... almost got fooled myself months ago.
I have both the Cats Paw and the Stanley demo drivers. I like both. For the price, I would consider the Mayhews - a more complete set. Just be aware that those are made in Taiwan. Still, mine seem to be a quality product. Scarily similar in design to the Wiha versions linked above.
Oh... the earlier versions of the Stanleys had a little bit of play in teh handles. Almost like the plastic of the handles didn't quite fit the blade tightly. I contacted Stanley about this and never heard back from them. So, I returned the original set (the ones made in England). About a month and a half later, I got a call during a class... it was a Stanley engineer calling from Sheffield, England wanting to hear some details about my experience with the impact screwdrivers. Did not expect that! I told him what I had notied about the screwdrivers and went on my merry way. A few months later I picked up a set (again made in England) and they seem to have addressed the handle fitment issue.
Strange, but true.... :thumbup:
blue302stang
grapevine, texas
I have a set of the wiha extra heavy duty screwdrivers, and have yet to have a problem with them. Picked the 7 piece set up off of ebay for like $75
64merc
Texas
DDM
Good question to ask, but wouldn't they have to be covered since they are providing you a metal cap in which to beat on them with? I would really hope that they would.
BTW, metal capped screwdrivers are no replacement for a chisel, but I find that at times it is necessary to lightly tap the end of screwdriver to remove stubborn philips head screws. For them to offer metal capped screwdrivers tells me I'm not alone.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I have several impact screwdrivers, but I don't tend to loan them.
I've seen what poor (tool and cash) do to get by, also seen situations (air handler in an attic) where just enough water rusted the head to the item, and the floating gunk fills the head (no impact on site, I was the up the ladder and hand xyz to the serviceman).
J
JayL
Manila, Philippines
Are there other reliable vendors that sell Wera Chisel drivers online aside from chadstoolbox.com?
logical
Northern fringe of the Motor City Suburbs
Wera has a special chisel screwdriver line http://www.wera.de/en/produktliste_screwdrivers_kraftform_plus_900_serie_wera_the_chiseldriver.html
I've got the lasertip series (300), so I can't comment on their chiseling capacities but I think the grip and quality is great.
I have both..the Wiha Microfinish set does have a cap but they are way too pretty to beat on. The Wera chiseldrivers are what you want. I can't say I've beat on them much, maybe as an ocasional spreader bar to separate a clamp or something. What I do use on them is the hex located just below the grip. The big flathead and a cresent wrench get a lot of big screws loose even with grease covered slippery hands.
J
JayL
Manila, Philippines
I have one of this impact drivers but its more of the for home use type. Do you have something in mind more suitable for autmotive work?
tks
J
JayL
Manila, Philippines
QUOTE]
How is the Mayhews' grip on the screwheads. Will it be the same or better than that of FELOs.
tks
J
JayL
Manila, Philippines
eschoendorff
QUOTE]
tks
I don't know. Never used the Felos. But I can tell you that I am not disappointed with my Mayhew drivers...
64merc
Texas
Well, I was killing time this weekend at Home Depot and finally broke down and bought this set for $10. They had both the made in England and made in Taiwan versions. Guess which one I bought? I haven't used them yet but I like them already. Haven't said that about a Stanley product in a while.
v8garage
Texas
I was thinking the same thing. I don't remember very many specifics from the little bit of shop class I had in high school. It was just a small part of a vo-ag course, but one thing that was stressed was don't use a screwdriver for anything but a screwdriver. They are not chisels or prybars. Not to say I haven't used them for those forbidden purposes in the ensuing years but I always felt a little bit guilty when I did. LOL
66HertzClone
Long Valley, NJ
Try here, Wera I ordered a set of Wera drivers from Chad's, they took forever to send the set I ordered. It arrived less the smallest flathead driver which arrived separately over a week later. I have no experience with site, I searched and found another outlet in case I wanted more Wera tools.
hamburglar
As I read that, they charge $28 for a single screwdriver vs. Chad's selling a set of 6 for (I think) $36.
wilbilt
NorCal
I recently bought some, too. Primarily based on eschoendorff's recommendation and the fact they were there and NOT made in Taiwan.
I have used them, and am quite satisfied.
hamburglar
That's for a 250mm version. I was only commenting on the chisel driver that 66HertzClone linked...
I looked on Chad's website and it's only a couple of bucks cheaper, so that must just be what those cost.
To everyone else, I wouldn't hesitate to order from Chads Toolbox. I've always gotten everything I've ordered from them in a reasonable amount of time, they carry a lot of stuff that is hard to find, and the free shipping on $150+ is not a bad deal.
