Metal-Cutting Oscillating Blades
Stuey
28m above sea level
Over at ToolGuyd I conducted paid testing of 3 brands' oscillating tool blades for Bosch.
I'm a scientist by training, and so I eliminated all of the variables I could by constructing a testing sled and protocols to follow.
If you use metal-cutting oscillating blades, take a look at Parts 5, 6, and 7 of my post series, which discusses cutting speed, cutting performance, and durability.
http://toolguyd.com/tag/omt-metal-blade-comparison/
If you only look at one post, look at Part 7, which shows blade wear.
http://toolguyd.com/oscillating-tool-metal-blade-best-durability/
I tried not to say this in the posts, but I am shocked at how different the blades perform. The Bosch blade is thicker and has carbide teeth. Imperial and Dewalt blades are thinner and with bimetal teeth and titanium nitride coatings.
I thought that, since the blades are pretty close in pricing they would perform similarly, and that the thickness of the Bosch blade would negate the hardness benefits of carbide. Nope, I was wrong, there are substantial differences.
I :shocking: when I tested the first series of blades.
whyNick?
Midwest
Interesting test(s). The Bosch blades seem expensive but since even the cheapo HF blades cost $8-$10 apiece they might not be such a bad deal...
Ign
Butte Peak ND
Cool! I'd like to see testing of a more "gearhead" application, like cutting an access hole in a floor pan....
Stuey
28m above sea level
The Bosch blades are $18/each, $32-35/2, or $100/10. Imperial and Dewalt blades are about the same price. If there was a substantial price difference, I wouldn't have taken on the project.
NoahG
Detroit, MI
I keep hoping they will make a blade that can cut more than one drywall screw without dulling.
Stuey
28m above sea level
Drywall screws and stainless steel threaded rod obliterated all of the blades. Bosch's held out a lot longer, but these materials are just too hard.
foodgroup
Florida
Hi Stuey, that was an interesting test, thanks for posting it.
I have never used an OMT so this is a newbie question.
I see how handy these tools are when you have a tricky access issue, but if I were cutting a nail, I would normally grab an abrasive cutoff wheel over a bimetal or carbide saw.
Do any of the blade makers have a "grinding" blade made of abrasive grit?
cheechi
Triad, NC
All of them make abrasive, including carbide grit. However you would want to use a cutting blade if you're cutting a nail sticking out of wood. The abrasive isn't needed.
Monte
Germany
<iframe width="640" height="360" src="//www.youtube.com/embed/Lw-of9w-5sw" frameborder="0" allowfullscreen></iframe>
Casey69
Earth
i noticed that about the bo$ch blades too. menards also has a 3 blade "tool shop" branded set for $10 & that's the cheapest i've found. they're fine for wood & pvc, but they don't last cutting metal. stepping up to a carbide bosch blade (or carbide-branded anything) would probably be best for metal.
regardless, i got my first cheapie oscillating tool at menards & they're great! didn't figure i'd be using it much, but can see how handy they can become.
