The type of steel frame you have pictured is only any good if it is inside a brick wall and lined with sheet rock or other panelling.
That system is used a lot here in Australia for housing(your pic looks to be an Aussie building site) with the advertising that it is termite proof and recyclable at the end of the buildings life. Supposed to be quicker to build.
These houses are ****, The main reason is that they too readily conduct heat regardless of what insulation is fitted. Its common here for black or slate grey steel roofs to be fitted which **** in the heat from the sun and conducts it down to the ceiling frame and gives you a nice big heater above your head in summer. Does the reverse in winter.
The frames have only enough strength to hold up themselves and the needed panelling. They are a pain to mount anything to the walls. There is no strength in the trusses for loft storage and they are a ***** to climb through to install services and ducting.
For the size you are building, the bracing would be very critical and 30' seems a long way for a light gauge bolted truss. Used in houses, the interior walls provide bracing as part of the wall frame. in a garage you only have the back wall to resist racking.There are no poles set into the ground for stability, the frame is just ramsetted into the slab.
Yes I hate them with a passion.
