Metal Halide light problems
James Aiello
50 miles West of Chicago IL
I have outdoor Halide light 2 stories high. It does not come on when it gets dark anymore. I changed the capacitor last year and that did not work. My
neighbor got me a new capacitor rated for -40 C and it still did not work. When
I installed the last one I covered the light sensor and the light came on. It was 75 degrees out when I tested it. Later that night it did not come on.
Could it be the bulb? Is there a temp range for them?
It did work a couple times this summer when it was about 85 degrees at night.
Like I said earlier it is mounted on the side of my house 2 stories hight and I have to hang over the edge on my roof to access it. Not fun, would like another
solution for mounting to the house.... cheap.
thanks
James
Aceman
Eastern Oregon
You need a meter to check your light properly. Anything else is a guess and replace method, which doesn't go along with "cheap".
DoyleDee
North Texas
I would replace the photocell and the bulb. We have hundreds of metal halide lamps around my work... If it isn't coming on, it is mostly a bad bulb, cap (most will swell and leak- plastic type spews a "plastic snake") and photocell. Of course we use 277v power and we test them at our shop before we put them back out. (Some of ours have a "pull out carcass")....we can bench test.
