HemiRambler
My buddy ran a lathe his entire career, 6 months before retirement - he lost a finger running one. Point being no matter how experienced you are - you can't let your guard down for a single second. Having dispensed that warning...you are effectively saying "I've never driven a car before...which one should I get?" It's a bit of a loaded question. I work on cars, and some race cars - to give you an idea of my typical projects. I would NOT consider anything much smaller than a 12X36 - and bigger IF you have the room (think of it as a 70's Nova - sure you could get a Yugo and it'd take you to the corner just as well, but won't pull that trailer very well either) really depends on your goals. I'd also AVOID flat belt machines because they typically wont have the speed to run carbide tooling very well - which generally means getting something made in the 60's or later. You definitely want the ability to cut threads. Personally I can't stand the sum-flung-dung stuff but depending on your location you might not have a choice. Regardless of what you get - these are DANGEROUS - they can certainly be operated safely with TRAINING. If you have a local community college around - you might do well to see if they offer any machining classes. They will get you started off in a direction prone to keep all your fingers. (Just watched a video of a "self taught" lathe operator yesterday - his "being careful" was basically a horrible accident looking for a place to happen- and he didn't respond very well to those that tried to offer him some guidance. Don't make THAT mistake. I just moved a 12X36 from a basement - it was a 1,200lb. machine that the original owner had passed away - that is a GOLD mine for a home guy trying to get a decent machine! Be patient, let your buddies know, talk to the local machine shop - they might have some good advice for you too! Bets of luck in your search - it is definitely worth the effort in time and money to let you look at fixing things in an entirely different light. Here's a bending die I made on the lathe for a tube bender. Fun project!
toy
