Good morning, my project is a steel pole building/garage. The building is framed and it's time to pour. I ran into a problem with the elevation of the metal siding and trim. The framer tells me that he pours the slab/apron against the metal trim on the jambs of the overhead doors. Said he has been doing it for years without problem. It goes against my intuition, I think the concrete will cause the trim to rust. I checked with the manufacturer, they said don't do it. I checked on line, it appears that the jamb trim is either installed above the concrete apron or cut to stay above it. If any of you guys have a similar set up I'd love to hear if you poured against the trim or cut it to keep it out of the concrete. Thanks.
The guy told me that his office is a pole building that is 35 years old. The apron was poured against the metal jamb, no rust or problems after 35 years. I think he being straight with me but it still goes against my grain. I think I will install a piece of 1/8 inch foam insulation (sill sealer or rigid foam board) against the metal and pour against the foam. I can push it down with a spackling knife after the concrete sets and fill the gap with caulk.
