metal ramps from HF
M-EGT
PHX
Just bought the pair of metal ramps from Harbor Freight, on sale for $40, used the 20% coupon bringing my after-tax total to $34.
Best part, they are made in the USA :thumbup:
Anyone else use them?
Hootbro
Delaware
I bought a set of these and trashed them the first time I used it.
As previously mentioned, if you have anything that is low to the ground like any standard sedan, they will not fit. I tried on a Honda Civic and Toyota Camry.
Anyway, I have a full size Toyota Tundra and the factory tires are way wide for the ramp for one thing. When I tried to drive up the ramp gingerly and not overshot the top flat part, the ramps skidded about 6" on asphalt and tweaked in the front inboard radius bend and developed a crack. After that, they could not be trusted and I threw them in the scrap pile.
I will take a picture when I get home later and post. This design might have been fine for 1980's and back designed cars, but any truck or SUV today, I would not use them.
Super Sport
West Michigan
Not to **** on your thread, but Rhino ramps are around the same price, also made in the USA, wider, and can accommodate most lower cars (my Camaro has never had a problem with them).
M-EGT
PHX
Thanks.
I plan to use it for my '67 Buick.
Definitely too tall for my Ford ****** though
M-EGT
PHX
I'll take a look into it.
tribbles
Las Cruces, NM
Stamped steel ramps give me the heebee-jeebees. I've got a pair I got for Christmas back in the '90s that I only dared use under a Ford Festiva.
aka Larry
Eastern, NC
+1 for Rhino Ramps. Lighter, stronger, and have a better approach angle.
theamcaddict
Bridgewater, NJ
The rhino ramps crack sometimes so even they are not invincible. For $40 ill buy an extra set if they are Made in USA:thumbup:. I have a metal yellow pair that have been in heavy use and have not let me down yet. I still like the rhino ramps for certain applications , especially on smooth concrete or for lower vehicles.
Coach James
Sandhills of North Carolina
My dad has been using a set of steel ramps from K-Mart for 30+ years. For my Saturn, I tool a pair of three foot 2x10s, drove 2 spikes into the end of the boards, bent them 90 degrees and put them in the ramp holes half way up the ramps. Made it easy to drive my Saturn up the ramps.
I have Rhino Ramps and like them. Much better for my wide tire vehicles.
Nice to see HF selling a USA made steel product.
Coach
M-EGT
PHX
here it is
Hootbro
Delaware
Below is a pic of my set that shows the crack on the right ramp and the mangled leg on the left ramp.
In reading one of the other HF reviews, another guy also claims to have collapsed his set with his truck. I do not trust them.
jamesemery728
Any ramps that leave air between the bottom of your tires and the ground can collapse. I have had good luck with Rhino ramps, but always keep a jack or two under the car or a set of jack stands. Don't let any ramps give you a false sense of security, build yourself a set of solid wood ramps that can not collapse.
mmack66
Kansas City, MO
I have some of the older style Rhino ramps, and under proper use, I don't foresee a situation where they could collapse, though I have heard that the newer Rhino ramps have a lot less bracing in them.
jonathan75
NC
The set I got 18 years ago from Kmart looks like it is from the same factory or mold. They have been great. At the time they sold these adapters that were heavy duty plastic that helped with low profile cars. I have the adapters that attach to the ramp.
Coach James
The one that is cracked looks like the crack is covered in paint. Did it come from the factory cracked?
The lower rated Rhino Ramps have less bracing than the ones rated for a higher weight. When I bought mine, I think there was just one version.
Coach
Hootbro
Delaware
Coach
Do it did not come cracked. If you look, the crack is in the valley of one of the stamping creases.
When I drove my truck up on them, their was an audible tone when they cracked that I heard. The other ramp on the left but not in the camera frame also has a like crack.
My truck was well within rating of these ramps.
jonathan75
NC
Here is the only picture I could find of my ramp that looks just like the HF version. My Son was helping me change the oil. He was two years old in this picture. My ramp is very old but it looks like it is from the same factory. If I remember correctly I got it from Kmart. If you look closely you can see the low profile adapter at the end of the ramp. It was sold separately as a kit.
ATC
VA
I have never used those metal ramps because I don't trust them. I've seen/heard of too many folding up. Besides...all the trucks I've owned have been too heavy for them.
I use Rhino Ramps. I've had a pair for about 8-9 years now, and use them exclusively on gravel under my 3/4 and 1-ton trucks. I just wish they were taller. I've had plans drawn up to build a set similar to "alan camby"'s above for a while now...I just haven't had the spare cash for the steel...
Skin
Boston
USA or not those things look sketchy as hell. Another negative, you'd need to put plywood under them if you have an asphalt drive to keep them from sinking in.
wkohler
Phoenix, Arizona
I have a set of Rhino ramps but I really don't like them. Most I use them for is setting wheels on them while jacking them up. I have found them nearly impossible to actually drive onto since they just skid out of the way. The non-skid rubber pad is hardly adequate, particularly when all of the force is exerted at the approach. I have used expansion joints to aide with that in the past, but I decided it just wasn't worth it. That's what makes some of the heavier options more appealing. It's gotten to the point where I don't much trust jack stands either, particularly those that make a very small contact point with the car.
Skin
Boston
I've done this to but attribute it to either unfamiliar throttle response or a very touchy peddle.
Vvmvbb
CT
When I use the Rhinos, I jam the ramps under the wheels and then ease up. They don't slide, and I don't have the rubber piece. Maybe that will work for you.
Goon
Great Lakes Region
I first bought a pair of the steel ramps at Napa about 6 years ago because I didn't trust plastic ramps. I always used steel ramps but they were my Dad's so I had to get my own set eventually.
I have driven my Jeep Cherokee, Crown Victoria P71, and my K2500 up them and I have NEVER had a problem or felt concerned that they would fail. I'm not sure they are the same as the HF ones, but I've only seen one version of these in the last decade.
That being said, this year I bought a set of the max weight rated Rhino ramps for around $55. I needed them for working on my Subaru Impreza. As said the metal ramps are pretty tall. I've used them with my K2500 too and had no issues. I like that they are wider and the K2500 is tall enough to crawl under with no ramps so the low Rhinos are fine.
I would not dare use the Rhinos in the winter. It gets below zero here and I have to work outside or in unheated garages.
tomshep
There are two versions. The older ramps are black and have a number of ribs in them underneath. I recently saw a set that were gray and were rated much lighter with less ribbing.
Tom
e-tek
Saskatoon, SK
^^ Only on GJ does a guy show his new purchase, get razzed for it, then it turns into a "lhere's how I built it - but better" thread....
LOL!! :)
cajunfirehawk
Ms Gulf Coast
I use a combo of: Rhino ramps, a floor jack and or jack stands = my redneck lift...LOL
Saw the steel ramps and passed. My F150 on those would scare the **** out of me...
