Metal Roof Snow Issues
craigibc
Western New York
I just built a shop on the end of my garage and I got a new metal roof on right before the weather went sideways. We are getting buried with now right now and when the snow is falling off the metal roof it is pilling up in front of the man door. Both roofs slide the snow right to the door opening.
Is there any way to prevent this besides a shovel of a snowblower?
Grimm_the_Grey
Central Pennsylvania
for snow retention, your choices are the cleat-type and rail-type. Search for "snow guard" or "metal roof snow fence" or maybe metal roof snow retention for a broad overview of the different options. other than snow retention, the only other option I can think of is designing a roof around your entrance and exit areas and walkways so that snow is shed away from these areas.
ybnormal
-put some 4" high flashing on the metal roof so it will slide to the right
-put an awning above the door
Von Psycho
Holmes Hollow Ontario
For security reasons your door should swing inwards (pretty easy to knock out hinge pins),
I like ybnormal's ideas and get a roof rake so you can bring down snow before it builds too high.
yeldogt
That's is a ------ Why did I not see that. We have all had them if you build enough. What's the roof we can not see?
The problem with the industrial type that screw down --- they can leak when you back the snow up w/ guards
Cane you move the door?
Showkey
"MEMBER EMERITUS"
Wausau WI
Let come down and plow or blow it away.
Some believe not holding snow and ice is a benefit of a metal roof.
Careful not to let come down on you, the dog or your car. Neighbor totaled their new car with a large snow and ice slide. They slammed the door and heard a BIG a crash noise.
Snow guards are the other choice as mentioned:
u2slow
BC
When hinges face out, you use special hinge security screws with raised heads.
The pitch, and being steel... it may come rocketing off there at the slightest accumulation; as it does with mine.
C
craigibc
Western New York
Wow I never knew what I was getting into when I installed that man door. We might want to change it in the spring. Thanks for all the great advice!
slowtwitch73
Hellgate
New door and some kind of covering.
Metal roofs are the pits with snow. I would hesitate to put on cleats, as the snow then accumulate so much it all lets go ina massive avalanche ripping the cleats out with it. And they leak.
You will probably also get soaked walls from rain splash, and wont be able to run gutters because the snow will rip them off.
H2R
Saw that once too. It never occurs to you that snow on a metal roof could be dangerous until you see it flatten a couple of cars like a pancake.
Renegade1LI
long island ny
What you need is to add a gable reverse that projects out about 3’. In snow country it’s always a good idea to have covered entry ways.
zoepop
My FIL's barn is 3 stories tall. So far he's lost 2 trailers and a truck. Always, " I'm only going to park here for a minute...."
4 FN 27
Minnesnowta
The Snow Stops work great. Just need top make sure your building can handle the load.
I don't want that kind of load on the roof with Snow Stops holding it back. The first couple of years the snow would slide every time it snowed. Since I believe the roof has weathered and will hold snow all on its own until the sun angle gets high enough or it warms up.
Then I get the massive slides, this one woke me up in the middle of the night. I heard it 400 feet away.
Need to park far away from the building in the spring if the snow is still up there. This was close too...
kelpaso1
MEMBER EMERITUS
New Brunswick
And another problem with snow sliding off a roof is, if you don't get to it till the next day it sets almost like concrete so that a walk behind blower can not power through it. Same as at the end of my driveway. If I dont get at it within an hour of the plow going by I'm not getting through it. I'm done blowing my drive and just pay the local guy with a tractor/blower to do my drive now.
FMB4
Adding a 'strip' or dam will only make things worse. First, you won't be able to rake the snow off that section of the roof. Second, you'll be increasing the snow load on that section of the roof. Typically such buildings in snowy regions have a single pitch roof that slants towards the rear of the building (that has no doors.
TurnipTruck
Southcentral Alaska
2B01C35D-99B7-4FA6-A0DB-3980E0A681CC.jpegI want the weight off my buildings.
I don’t know if this pic fully demonstrates the volume of snow to you, but this side of my steel roof is 32x64’, and the lean-to posts are 12’ tall. This berm is probably 90 tons of snow.
If we assume 3’ of snow, this roof could have between 23 tons of fresh snowfall or 115 tons of rain-soaked snow on it.*
Minimum code around here is just 45 lb/ft2, so it should handle 86 tons, but I have to worry about the building surviving acceleration of that kind of mass back and forth 14’ up in the air in another 7.2 earthquake (like last month).
* 4lb/ft3 fresh snowfall to 20lb/ft3 for saturated.
mikedodge
Do this or build the roof back up on an angle over the door to funnel the snow down beyond the door. You don't want to put anything up there that prevents the snow from coming down or else it will pile up at the edge of the roof and cause other problems.
PoorUB
Fargo, ND
With the snow dams I would not put up the large, solid one, just he smaller likr 2x2x2 angles. They slow the snow down a bit and help it break up so it doesn't come off the roof on one solid mass.
We had a huge storm here a few years ago. There is a large trucking company and their building had a lower roof where the snow just drifted and piled on. I drove by it in the morning and it was maybe twenty feet deep. They sent a couple workers up on the roof to clear it away and while they were up there the whole works came down, buried them in the snow and killed them. So it isn't something to screw with.
Showkey
"MEMBER EMERITUS"
Wausau WI
Once the snow in off the roof and on the ground near the building……..it still needs to be managed.
There 20 prior threads on snow melting causing building wall, stem wall leak, foundation issues.
jollygreengiant
Ontario, Canada
As others have said, there isn't really a good option here other than to just accept it and deal with the snow once it's on the ground. I'm not a fan of snow dams as they keep the snow on the roof. Personally I'd rather have it on the ground, especially here since we tend to get a lot of wet heavy snow. It's a lot easier to deal with the snow on the ground vs on the roof.
If your concerned about the snow coming down on you, you could install an awning type structure over the man door.
KEH
Good info. I'm in warm SC and recently had a metal roof installed on the house. We had a couple of inches of sleet and snow combination and after a little sun and warmer temperatures the stuff on the roof started melting and the mix started sliding off the roof. No damage but it piled up on the shrubbery. Will have to watch out for it in the future.
KEH
