iamhomeless
The west wall of my old mortise and tennin barn is in rough shape. It's the long walk of a lean to addition of the main barn that was a milking parlor when this place was a dairy farm.
Lots of bits of broken siding and the bottom edge of the old wood siding is rotting out. The sil plate is mostly ok. As are the bottoms of the old square posts where the mount to the sill plates, thanks mostly to the nice tall concrete curb. When I bought the place I put some plywood up on the inside and then stapled and taped visqueen on the outside stop (slow) the damage, but I need to go ahead and fix the issues. The wood siding is in pretty good shape aside from the bottom 12" for the most part and has some nice character to it.
I was thinking about putting up some metal wainscoting on the lower 3' or so and leaving the upper wood siding in place. Plan would be to z flash behind the upper wood to the metal to keep water drips from getting behind.
Should I fully strip the old siding from the bottom and sheath with plywood for a backing, or can I get by with using the old wood siding as something to screw the metal into?
