1930artdeco
DIY beginner welder here with a warping question. Is it possible to determine if the metal at a weld will either raise or lower due to warpage by looking at the seam where the two metals meet? The reason I ask is this, I just did a but weld (steel to steel-19 ga.) and I thought both pieces were level or just slightly higher/lower. Slowly did my tack welds all the way around being careful to not let the metal get too hot. I noticed that one corner and partially that side 'dipped down a bit'.
Now I did not clamp the two pieces together as they fit so well together that I just zapped them together. Great and kept on going. Then I noticed as I continued on that one corner dipped down a bit-plus I could hear it either popping welds or kreaking somehow. Would a clamp of some sort prevented this from happening?
Thanks,
Mike
Thanks,
Mike
