just finished putting down some 100% solid epoxy w/ cheaper epoxy base coat with Cohills Quick silver-- and mixed in a batch of black onyx
here's the results so far....
They gave me alcohol to spray on at the end to give it a bubbly acidic look, which I passed on after we squeegeed it out. It was also recommended that we back roll it, which we passed on. The spike shoes was making marks with the spikes and straps, and the epoxy was hardening quick as it was only around 55* when applied. I did some research and found a YouTube video by concrete designs that I tried to emulate, except they used a light tan and a brown....think I may apply the top coat tonight
Seriously? It's been 48
The epoxy went down perfectly, how could I have not waited long enough, if some people are saying to apply within 24 hours.sounds like epic fail buddy. Sounds like something wasn't cured yt and you applied a top coat anyway. From the sounds of it, you will have to scrape it all off, solvent scrub it, possibly grind it off.
Would be best to research more before you apply any chemicals to avoid a disaster in the future
