Metals reference
1190R
I now have a welder and am planning on getting a lathe and mill but realize that my knowledge of what metal to use and why is very limited to say nothing of all the abbreviations when ordering
What is a good reference text or online resource to educate myself?
thursday
Utah
There's a whole number of considerations that go into answering your question of what metal to use and why. The more you can narrow down your requirements the better. Material properties only make sense in the context of application.
Imagine being asked "What is the best tool to use?"
If you strictly discussing metals to play around with on lathes and mills a good property to learn and evaluate would be "Machinability".
The question of machinability is full circle again leading to the question of how good your machines are (rigidity, power etc.. )
Aluminum 6061 is relatively cheap, has good machinability, and good for practicing machining skills.
Aaron_W
What makes a metal good for welding and good for machining are often in opposition.
Online metals also has a good resource. If you go to the bottom of the page look for the links under learning center. There are weight calculators, material properties, hardness conversions etc.
Online metals
toglhot
You're making it more complex than you need, keep it simple: Stainless, steel, brass, aluminium and plastic. Obviously there are grades, but, for a start you can't beat the KISS principle.
CraigStu
Blacksburg, Va
Go to McMaster Carr for excellent info also.
