Meter base and disconnect ?
clonestocker
After much thought I'm that I want a meter base and disconnect outside and my breakers on a sub-panel in the garage. Any advise for keeping the meter base and disconnect simple. I can't seem to find anything I like. What does the forum on think? thx matt
Terry D
St. Louis, MO.
All most all the combo style ones are.going to have some spaces in them for a few circuits. The only other wa is to get a separate meter and enclosure with a main breaker and attach them with a ******. What size is the service
Sent from my SM-G960U using The Garage Journal mobile app
Norcal
A meter can and either provision for, or a factory installed, main breaker are manufactured, check the Eaton B-Line (former Circle AW Products) catalog and other manufacturers offer it also.
Theres a alot of Circle AW stuff out here in the valley. Mainly combination meter mains. Seem to hold up well. Some of it is on homes from the 70s and 80s
Norcal
Circle AW started in Modesto, & for smaller installs of non residential metering they had most of the market.
nadogail
Coronado, CA
We use a lot of Square D combination panels with the meter base and circuit breakers accessible from the outside of the structure.
