Metric Bolt Grade Help
owenst7
Anchorage/Reno
I have never heard of Grade 9 bolt and this is what I have been able to find on google
https://www.earnestmachine.com/documents/training.pdf
Grade 9 would be a SAE classification. There's a dot above (pictured) the number, which tells me that's actually a 6. I believe all SAE fastener grades are denoted by hashes anyway. Grade 9 fasteners are pretty common by the way.
That's not a standard metric classification that I'm aware of, but if it follows the same system of marking, a 6 would denote a minimum tensile strength of 600 MPa. I'm not sure why it wouldn't have the percentage yield after though.
I.e. a metric Class 8.8 fastener should have a min. tensile strength of 800MPa and a yield strength of 80%x800MPa=640MPa, similar to a grade 5 fastener. Class 10.9 is similar to Gr8.
scratchedup
Fayetteville, GA
I found this on the Pelican Parts Forum-
"SAE Grade 8 (150,000 psi tensile strength) is equivalent to metric Class 10.9.
SAE Grade 5 (120,000 psi tensile strength) is equivalent to metric Class 8.8.
Metric Class 4.6 and 4.8 are equivalent to "mild steel"."
SteveH-CO
Southern Colorado
Some older Toyota bolts (1970s-era trucks) have a value on the top which, when run through a calculator, gives the proper torque value for that bolt. It is not an indication of bolt strength. Not sure if that might be what you're looking at.
600SL
Connecticut
I just ordered some grade 9's yesterday from Mcmaster. But they were SAE. I have no idea what those are.
What kind of car what do they hold on.
