redragoon
Couldn't find much discussion about slim ignition wrenches that weren't vintage. I wouldn't mind a set of those, but I don't have time to hunt at the moment.
Background: I have a new cheap 3D printer that I am using to make small tools and repair/replace broken plastic in things I am restoring. It came with a couple of the terrible stamped steel wrenches for making adjustments. One of those wrenches is already damaged and will not work, but there are some small spaces that my other narrow wrenches do not fit.
At work I have a small Stahwille 12/10 5mm ignition style wrench. It is the wrong size, but fits the tiny slot on the machine. This wrench is ~2mm thick.
Since everything on the machine is small, I figured I would get a metric mini ignition wrench set, but I can't tell how thick some are. The set needs to cover ~4mm to 10mm.
I need it to be the same thickness as the Stahlwille, but I'm wondering if I should just get the 12/10 set anyway.
Does anyone have some other suggestions from other manufacturers? Japan, Euro, USA preferably.
