ckucia
So I'm sorting through my can of fasteners.
In the past, I've had drawers for standard fasteners, but I never had enough metric ones to justify their own drawers.
Now that it's been a few years and we've been through several cars that were exclusively metric, I have a fair amount of metric fasteners to sort.
I noticed the other night that M6-1.25 bolts fit 1/4-20 nuts and vice versa.
I did the math, and a 1/4-20 works out to a M6.35-1.27. Likewise, a M6-1.25 ends up being .236-20.32.
I assume there's enough slop in the threads, especially in a nut that doesn't have many, that it makes these two sizes appear to fit each others' bolts/nuts.
I also assume that, if I had a decent length threaded bore, that the bolts wouldn't go in the wrong bore, although I don't have anything handy to try that out.
I suppose if the threads aren't too sloppy, I could put a set of calipers on the bolts and sort the two out by OD. Not sure if that would work on the nuts.
Curious if anyone else has come across this, and how you deal with them. Just throw 'em all in the same drawer with both labels and sort it out when you have a deep bore? Get a better set of thread gauges (I usually just use a known-size nut, but obviously that system has broken down)?
Are there any other common fasteners that appear to interchange across both metric and standard?
The only reason I caught this one is I happened to have the metric ones in a pack from the parts store with the M6-1.25 label still on it. Otherwise, I would have just assumed I tossed a standard bolt in the metric bolt bin and set it in the 1/4-20 drawer.
and then there are those BA, and CEI, and BSP (maybe) threads, and prolly a few others...
