Metric Threaded Inserts for Wood?
propav8r
Franklin, NC
So I've started cranking out some shift knobs on my lathe, but am having a problem finding good thread inserts to use.
Most of the ones I have made are going on T5 transmissions, and the most common thread (it seems) for those is 3/8-16. That's no problem, the local hardware store keeps those inserts in stock. They look like this:
I can get those up to 5/16 thread.
The problem is when I'm looking for metric inserts. Quite a few people have requested M10 or M12 shift knobs, but I just can't find anything that even seems like it would work.
As a side note, I can find knife thread M8 inserts no problem. Just seems like nobody makes them bigger than that.
Can someone point me in the right direction?
gungatim
west mich
no, but could you countersink a metric nut and fill the surrounding with epoxy? like drill the deep hole for the shaft first, tap it, then countersink a larger hole just deep enough for the nut and epoxy it in there. you'd get the dept you need for the shifter handle to not break the wood, plus the nut would keep from stripping the wood...actually drill the counterbore first then the smaller hole but you know that...
Lassen Forge
MSC maybe? Or Fastenersuperstore dot com? Shy of that, you may have to check some of the European supply houses... The little local ferramenta (hardware store) in Valfabbrica had them (all sizes) when we were there (had to repair some Ikea-ish B-I-Y Armoires) so I know they're not that uncommon, once you cross the pond...
P
propav8r
Franklin, NC
I had thought about that...that might wind up being my only options, but I'm not sure I like it. I just don't see it holding up well for thousands of miles and thousands of shifts.
EdT
North Georgia
I have never had anything at McMaster show up in a google search which is unfortunate. You just have to go there and search. Their front end is better than any of their competitors, but searching sometimes requires a creative choice of words to find what you're looking for. For example,IIR, I was looking for some replacement hole punches for a RW hand punch. Searched on "punch" , nope; searched on "hole punch", nope; searched on "hole making punch", yup. They do not list many things by brand name either. Still the first place I look for anything. They probably have it if you can figure out what they call it.
