Joe Piro
My question is: Knipex (and others) make wire strippers that specify AWG sizes and different strippers that specify metric sizes (usually in wire area, or millimeters squared).I've learned this much in life.
Buy Metric Strippers and Crimpers if you work on European/Japanese vehicles. I'm guessing most USA vehicles that use European electronics from Bosch/Siemens etc. Will probably be Metric by now.
However Knipex explains in their complete catalog, that some of their metric devices also work on AWG wire.
DO the metric strippers really work for AWG wire???
For example (see photos- I included photos of the stripping blades; a square symbol at the top of the blade means "metric wire area; AWG obviously means AWG. ): I think its only the second photo "Chart Detail" that has good information on this post. I just got carried away with the others. Everybody always says "Show photos."
So:
Knipex Stripper 12 12 02 is precisely for metric .03 through 2.08 square mm but suggested it works for AWG 32-14.
Knipex Stripper 12 12 06 is precisely for metric .14 through 6.0 square mm but suggested it works for AWG 26-10.
Knipex Stripper 12 12 10 is precisely for metric 2.5/ 4/ 6/ 10 square mm but suggested it works for AWG 13 - 7.
Knipex Stripper 12 12 13 (and 12 12 14 also) are precisely for AWG and not suggested for metric.
I tried to calculate and compare the different wire sizes and the stripper knife hole sizes, but I finally quit trying because of so many variables such as solid wire versus more than one pattern of multi-strand wire. However it seemed to me that even with a precise AWG device, there were anywhere from 5 to 10 thousandths clearance between the blade and the wire, on each side of the wire, depending on the wire size.
So... bottom line... if you want good results and you don't want to Knick the wire, is there enough clearance between the stripper blades and the wire and does it work to use a metric stripper on AWG wire or vice versa;
OR do we really need twice as many stripping pliers.
BTW I know some of you will respond "Just get the Weicon No. 5... it works on anything."
AND I have that and I use it for house wiring, 120 and 240 volt wiring, receptacles, panels, etc.
However someone else always says "This is Garage Journal." Get both!
Whichever you believe, the question remains: Do Knipex metric strippers work for AWG wire as claimed?
