Mice and garage couch
profisher
So right now im in the process of making one side of my garage into a man cave area. I dont have huge budget to spend on renovations and progress will be slow. I want to put a couch or some sort of comfortable seating out there, but i know my garage is not mouse proof right now . Anyone have a garage with a couch that has kept mice away from it? Is mouse poison a bad idea? I dont want to smell dead mice.
finn
The UP, God's country
I use snap traps, sticky traps, bait stations, and bag pellets.
Got two mice this fall and a couple of voles.
I never find corpses from the bait or pellets, and noticed no odor.
I think they go outside to die....at least that’s what I want to believe.
DFB
Southern VT/Western Mass
Wage war on them :D
Both work well for me the spring traps or the pellet bait (I use them both)
Just got 7, 6 in the garage with bait and one in the house with a trap and peanut butter ;)
P
profisher
Set up 5 traps last night and already got two of them. Maybe ill step up my game and get some of those pellots too.
RoyBell
Chicago
Start by closing up any gaps that they can get into from outside. I fixed many gaps are my current house and it has helped tremoundesly. Went from getting 1 every couple months to seeing 1 once a year now. My biggest area was the bottom plate of the walls that met the foundation wall in the lower level of the house. Builder had shimmed up the wood walls (late 60s) and that was it. There was a 2" gap to the outside world that was hidden by drywall and the sidding. When I re-drywalled the downstairs I found all the gaps.
I had a rental house built in the late 1800s. I could never get rid of the mouse infestation. That house was so leaky with many hidden openings. I was able to reduce them but never fully got rid of them as far as i know.
b-boy
Buffalo NY
They are brutal. They get into everything. They need a 1/4" opening to get into your building. It's hard to seal up a building that tight. Even if you do, they'll just sneak in when your doors are open.
Twice I've started up my lawn tractor and had a baby mouse shoot out of the tailpipe along with a bunch of nesting material. :D
I've tried poison and never had good results. They seemed to avoid it. I used the tip-up traps and they worked well. Problem was, when you let them out, they just ran back into the building. I have a few cats now, and there aren't as many of them, but I know they're still around.
bwringer
Indianapolis
Consider patio furniture instead of am in-house-living-room sort of couch. Far fewer places for the bastards to hide, and the cushions are usually tougher and less attractive to mice.
Use mouse traps, and check them regularly. No poison - that just means they'll crawl into the couch before they die, rot, and stink.
And consider installing a good cat, if practical. May not be the best option if you have a lot of chemicals around and vehicle traffic.
If you're rural, it'll be tougher to keep up with traps. In the city, I've found that trapping works fairly well. I use the snap traps that kill the mice - a little nasty, but if you use the no-kill traps and release them they just come right back in again. DON'T use glue traps; they're incredibly cruel and they're expensive. With snap traps, it's over instantly.
I've had great luck with these plastic traps; much easier and safer to set than the old "wire" style, and they don't seem to miss nearly as much.
https://www.homedepot.com/p/Victor-...VDoxpCh3gMAiKEAQYBSABEgJ5dvD_BwE&gclsrc=aw.ds
Stuart in MN
Minneapolis
I've seen mouse nests made from Bounce dryer sheets, so that method doesn't work. You have keep them out of the garage as best you can. Block any holes, check the gaps around the door weatherstrip, and so forth. However, if you're one of those people who leave the overhead door open, there's not much you can do other than using a wood park bench instead of a couch.
BuffettFan
Central Illinois
I would go this route.
My first house had so many mice, edge of town, surrounded by corn fields and a hog farm, that I kept a .22 revolver loaded with bird shot next to my recliner. Played hell on the paneling, but then so did the mice. :lol_hitti
Kevin54
MEMBER EMERITUS
Urbana, Ohio
^^^^THIS^^^^
My garage is finished off. It is sealed off, drywalled, and heated. You open the door to drive out and a mouse will run in. I've used sticky traps before, but a mouse CAN get off of one then go off and die. Poison pellets are supposed to dehydrate them where they won't smell, but they will smell. Best bet is cheap snap traps and peanut butter. Set a few along the wall and in the corners. Mice are timid, and hate to run across an open area. Plus a snap trap is a fast way to kill them. And forget live traps. If you turn a mouse loose, it will just come back.
ratdoggy
Akron-Canton area OH
^^^^THIS^^^^
I'm dealing with a rat problem at work. I started putting a couple snap traps side to side so the bastards have to walk across one to get the bait on the next one...Got one this morning as a matter of fact....
PS they like marshmallows
b-boy
Buffalo NY
Try this. Virtually free and you don't have to reset it after it catches one (or 6)
Ah yes. Nothing better than finding a swollen, bloated mouse corpse floating in a bucket. :D
My Dog used to drink out of a bucket like that in the garage. Every now and again, you'd see him standing next to it with a disgusted look on his face. When that happened, we'd usually find a mouse that tried to get in there for a quick drink of water and slipped.
Captain Spaulding
Southern Indiana
Wage war on them :D
Yep. Don't go halfway. Bait stations outside, bait stations inside, traps, seal every gap you can find and remove all sources of food.
P
profisher
Lots of good input here. Might have to consider the patio couch option. Also have thought of a garage cat, but not sure how they do in cold.
Jon_E
Southwestern Vermont
I have been using bucket traps (picture above) with great success in my garage and storage shed. 14 mice in the past two weeks, and I had no idea there were that many. Especially since I thought the shed was sealed up pretty tight, but still was finding mouse poo occasionally. I am leaving them in use permanently, replenish the peanut butter on the can (I use a soda can, not a plastic bottle, but either works) every couple of weeks, good to go. I think I may have to use some RV antifreeze in the shed over the winter, but the garage is heated. I still haven't found a nest in either building so I am wondering if they were transient or still searching for a winter home.
homelessdespot
CT
There's a guy on youtube who tests all kinds of mice and mouse traps. I believe he said his favorites are the bucket ones, and the one that is C02 powered and resets after every mouse/rat.
GrayFlattop
Chicago
And (at least in my experience) they typically just bite off the head. That's not enough to eat.
If you do get a garage cat, make sure that you remove all mouse poison.
I'm going to try one of those bucket traps. I use the blocks, pellets, snap traps and glue boards and still every once in awhile I run across their droppings.
rburke65
Canfield, Ohio
Yes.... it agood idea ....not feeding the cat. I use a raisin on the bait paddle. I stuff it under the paddle so they have to work to get it. Plus take a pair of nee$le nose pliers and squeeze the trigger a little making it more sensitive so that puppy trips with 5he least amount of movement
Jim 68 cuda
Virginia
I was also concerned about the possibility of mice getting into furniture. I also wanted chairs I could mop under and wipe down when they get a layer of shop dust on them. Always liked mid century modern architecture, so a couple of "barcelona style" vinyl chairs off Amazon fit perfectly with my plans. They typically only get used when I turn on the wall mounted TV, as most of the time visitors seem to prefer to sit on stools that I have in a few places around the garage. They make couches as well in this style.
GrayFlattop
Chicago
Much nicer than my upside-down 5-gallon buckets!
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A poorly fed cat will have incentive to find mice.
Rats, from what I have heard always follow a piss path. Meaning that they follow the same path in something like a garage. Traps need to be set in that path.
As far as a poorly fed cat....********. The fattest of cats love a challenge with a mouse or rat running around.
frank001
Southern California
I like the idea of the patio furniture. Glue traps work best for me. I also use the 'One Bite' pellets outside that seem to work pretty well.
bwringer
Indianapolis
If you poison them, they just hide, die and stink up the place. Not suitable for spaces where you live or work.
Been there, done that...
bwringer
Indianapolis
Buy yourself a couple black snakes and keep them hungry
A friendly garage snake is a great idea, but winter is coming... they can't move real fast when it's cold.
I knew someone with a sort of vacation home way out in the woods, and they reached a mutually beneficial arrangement with a large black snake. The snake gets warmth and water, they get to enjoy a mouse-free and rat-free second home.
It did take some getting used to... no matter how much you like snakes, running across a large, glossy example unexpectedly is a great way to get a little impromptu exercise. :scared:
Nowadays they have a pretty good idea where the snake might be hiding and don't usually get startled.
Moto
Bait boxes with bait blocks, but put them around the perimeter of your property.
And traps of some sort to get any that make it past the bait.
foodie
Check out the website Garage Organization, they have furniture for garages/man caves
some of it looks pretty cool!
Wpauley
Northern Illinois
I use the 5 gallon bucket set up. Have to use washer solvent in the winter. I have a wind up and several snap traps as well. Use the poison blocks, the hole in the middle I use to nail them so they are not carried off. I agree the pellets are just Moved around and I have found them when I was using them. I put the blocks in small squirrel traps so that other animals cannot get to them. Including my dogs. Problem with poison is that mouse eats poision and then is eaten by cat and cat dies too. Impossible to keep mice out of pole barn, just have to keep killing them.
Pluribus
Skagit County, WA
Dang near impossible to keep them out of garages unless you never open the overhead door(s.) I'd never want a fabric piece of furniture with all sorts of nooks and crannies in my garage. The patio furniture idea is a great one!
I'm a big fan of the 5-gallon bucket trap; the one in my crawl space works downright murderously well.
