so I just finished rebuilding mine.
I did not tear it down as far as the others did.
I figured out the 4 bolts holding in the jack, the bar under it and the pin that holds it to the lever, and the pin that holds it to the arm were enough to drop out the jack itself. Plus loosening the pivot arm so it would spread enough for the jack to come out.
I could not get the top of the ******** by hand. I tried a pipe wrench like the guy shows putting it back together in a youtube video.
but it didn't work for me. even took a 5 pound sledge to the pipe wrench.
found a 2 and 1/8 socket and used an impact gun to get it apart.
Like others I found the reservoir seal in the kids don't work. I reused the old ones.
The closing valve uses a ball bearing to seal, and I missed it falling out so didn't know I needed it. the video linked above showed me what I was missing when I couldn't get it to pump up.
I didn't touch any of the don't adjust screws. I only took apart the main body, pulled out the pump and the closing valve.
I replaced all the seals I found there. 3 internal o-rings as I recall.
one of the flat washer seals in the center under the slotted cap was a metal washer instead of the plastic the original was.
The washer that goes inside the pump hole was cut already so it would fit in. Getting the oring in there was a pain.
But 50 bucks later it works again and doesn't bleed down.
took me about 6 hours counting the run out for tools.
lot of the video's skip parts or go way farther to take it apart.
