Micky got the chair
andyvh1959
Green Bay WI
Working on installing GFI outlets in my kitchen remodel of my 1973 tri-level house. One outlet box had that distinctive mousy smell, ugh. It was a single box with three 12ga Romex circuits coming into it and all crammed together, with doubled up pigtails under the side screws like was commonly done back in the 70s. So I changed the box to a 2-gang, and added another outlet with the new GFI outlet. No more doubled up 12ga pigtails under the side screws. As let far as I know, its no longer acceptable to double up pigtails under each side screw. Just too many things to come loose or not be secure as the outlet is shoved into the box, plus even if secure, the screw heads project further out the sides of the outlet fixture profile.
Few weeks back I plugged the toaster into the old outlet and heard a "snap" and a spark, yet it did not trip out the breaker. When I got into the outlet box I found the source of the mousy smell, and it was obvious Micky got the chair. I found bite marks through the insulation on a black/hot wire, and,....the skeletal reamains of Micky, almost a complete spine/legs/tail, along with some fuzz. And a tiny weld spot on a ground wire that had likely touched the black wire through the chewed insulation. Luckily, the wires were just long enough I could cut the hot wire back to avoid the compromized insulation. So the little ****** had managed to crawl up inside the wall and into the outlet box.
Stuart in MN
Minneapolis
When I rehabbed the kitchen in my 1913 house there was knob and tube wiring in the ceiling. After I pulled down the plaster I found a mouse skeleton, with its nose against one wire and its tail against the other. I suspect he got zapped long before I was born.
A
andyvh1959
Green Bay WI
visual proof of Micky remains, for reference the main section of the skeleton is about 1.5" long,
even the metal single gang box that was his coffin stunk like mouse piss. I got that box out of the wall and replaced it with a double gang plastic box.
