Micro Drill Bits
SwissMetric
Switzerland
Various manufacturers, just as example:
Couldn't resist, some great screwdrivers:
There are many small highly specialized businesses unknown to the general public. Some don't even have good websites because they don't need any. Swiss precision is not a myth... neither prices.
mikey03
what kinda sizes do you run on the small end? What’s the smallest size and what kind of intervals?
i only used regular drill bits that come in 1/64 inch jumps and starts at 1/16” I think
Steve_P
I have two Norseman sets that I only use in pin vises. I don't know where I bought them, but maybe Harry Epstein.
W
Wamsutta
Amarillo, Texas
What material will you be drilling
I'm pretty sure it's brass. It's a carburetor idle jet that's non-removable. I suspect the hole diameter is right around 0.35 millimeters.
Yes I know I run the risk of getting black helicopters hovering over my house. 😁
Firebrick43
West central Indiana
Just order a Cleveland or Chicago Latrobe for numbered bits in brass.
They are good quality and there is nothing special need as far as bit wise.
I would suggest using a hand pin vise to do it. Power drilling with small bits requires good runout on the spindle and chuck that is missing in most home shop equipment.
W
Wamsutta
Amarillo, Texas
I think 1/64 is the next size up from #80. What kind of intervals? I think I may only do it once or twice in a long time. I'm mainly concerned about getting the roundest hole possible since it will be metering fuel. I'll be using a pin vise for sure. I have two Honda carburetors that are causing a very lean idle condition.
L.Cheapo
I use Chicago Latrobe 69867 #61-#80 set. Works for me. The set I have is a couple years old now and was made in Japan.
W
Wamsutta
Amarillo, Texas
definately by hand is the way to go. be careful & don't drill too large or you'll end up rich.
I would carefully gauge the hole with other bits until one doesn't fit, then drill with that one, assemble & try it . just move a size at a time.
Sorry, I didn't answer your question .
Do you think 0.40mm is the next step up from 0.35mm ?
gizardlizard
Madison, WI
YouTube: hand drilling brass orifices in gas valves. The old timers were great at it. You must do it with your finger tips and sneaking up on the needed size with 3-4 undersized bits is a must. Hand drilling a carb jet is no different.
NHtoolguy
Gilford, NH
I think the pin vise approach is a good suggestion. Small drills are best used in a sensitive-type drill press, with gentle hand feeding. The typical home drill press won't turn fast enough or provide enough control.
bwringer
Indianapolis
If the machine might ever end up with someone else, just document the alteration somehow... I have painful memories of chasing issues with a set of motorcycle carbs for weeks before finally figuring out someone had hogged out the jets.
RoninB4
Under My House
-I have one similar to this for small, sensitive drills. You hold the knurled part (bearing inside) and feed the drill with your fingertips so the drill press quill isn't used. Using a regular drill press quill isn't sensitive enough to provide feedback and will break small drills. There's also a type of drill press made for small drills but they're harder to find and somewhat expensive. Most toolmaker use a type like the one below, mine has a 1/2" shank for collet mounting but there are others.
CR888
If U buy a cheaper online metric chynese set, do have your calipers there to verify your using the correct size. They usually go up in 0.05 increments. A 10pc set may start at 0.3mm then 0.35 then 0.40 etc They cheaper ones can be ok and are often more like a reamer than a drill. If U go to far, dab some JB in there and start again. Pin vise and hands is best IME.
