1982fxr: Thank you.
Tool Scrounge: What do you use to clean the channels before applying the wax (Gulf Wax)?
Sorry I took so long to reply.
I posted this summary on on another post..
I soak slides in Kerosene and scrub with a tooth brush and a red Scotchbright pad if needed for light rust removal. I do this also to the slides mating surfaces on drawers and box. Note kerosene is flammable so I do it outside and obey safety notes on container. Then I carefully wipe dry with paper towels and q-tips before applying paraffin wax.
Please note when rubbIng on paraffin wax to Snapon drawer slides and mating surfaces, you can put too much on and have added drag from the wax. With Waterloo (old Craftsman) and Kennedy slides I have never seen friction issues with lots of wax, other than making a bit of a mess.
After I rub wax on all the mating surfaces, I install the top most drawer and vigorously slide the drawer in and out. Some of the wax will shed off to the bottom of the toolbox. Repeat with the next drawer down. Before putting in the last drawer, vacuum out the small bits of wax from the bottom of the toolbox
