How easy are the scissor style lifts to move around?
They are difficult to move around.
The lift frame has 2 wheels on one back end and the front rests on the ground.
The wheeled power unit (cart) has a pin that fits in a "hitch" hole on the front of the lift frame. You pull and push the lift frame around using the power unit cart much like a pickup tows a trailer.
To move the lift you have to LITERALLY lift the front end off the ground by using the power unit cart as a lever arm. The way everything is positioned requires the power unit handle to be pushed all the way down past 45 degrees to lift up the front of the lift frame pretty high off the ground.
The frame is about 800lbs so you have to hold all this weight UP, balancing it on the cart wheels WHILE trying to push and pull this entire thing around the garage.
Its a VERY STUPID design. I hurt my back twice moving this thing around.
Im in decent shape. First time recovery was a week. Second time MRI showed no serious damage, with probable pulled muscles and I recovered 8 weeks later.
If you buy one of these, get help moving it around. Consider making something that will fix the terribly awkward factory design for moving lift around.
