Midget/stubby wrenches: any feedback on them?
skernv99
VA
Stubby, a.k.a. midget, wrenches...well some tool brands call these type of wrenches stubby while others call them midgets. Whatever the name that's used, I wanted to get some updated feedback from folks on board on the usefulness of them, particularly the ratcheting versions.
Yes, I know the ratcheting head makes them a little thicker but overall, do people find stubby/midget wrenches useful? This would be for mainly automotive use, no small engine or big diesel stuff. I only started to get more involved in being a serious hack and doing more and more of my own automotive repairs and tinkering.
Fedwrench
Valley of the sun
actually, the stubbys are usually longer than the midget series but, that's another thread. Yes, stubby ratcheting wrenches can be quite handy at times, I like the stubby flex head set from gearwrench. The flex head allows better access in some situations, and they seem to be just the right length for me at least.
Two Speed
Ontario Canada
They all have their place. Unless your work is out in the open and fully exposed, you'll probably find a stubby wrench used more often than not. I have not had to cut any regular wrenches down in size since adding a set of stubbies to the arsenal.
Alex.
Tallpilot
Orlando
Midget wrenches are tiny in 2-10mm type size ranges. Stubbies are normal sizes 8-19mm. I prefer ratcheting. If you are using a stubby it's probably because there is barely any room and the ratcheting action will speed up the job.
Gearwrench flex heads are nice as are the Tekton. As far as I can tell there isn't anything to be gained here by spending big money.
marineman
Wild Rose, WI
I would never be without stubbies. I have both ratcheting and non ratcheting. I use non ratcheting the most because all my wrenches are usually backing up an impact but for normal uses I would get ratcheting only
Sent from my SM-G970U using The Garage Journal mobile app
Aqua-Andy
I agree, at the length of these wrenches you will never put enough torque to either break or spread the jaws. I had a metric set of Snap on stubby wrenches for years and when I needed a 9/16 for GM truck brake lines I picked up a set of Kobalt wrenches and they are in every way as usable as their SO counterparts, but at a fraction of the price.
johninct
Can be the difference between a 1/2 hour job or 4 hour job because can get into places.
ex-x-fire
Sheboygan Falls Wi.
One of my tricks on the stubby wrenches is to file the open end a little. It'll never round a bolt anyways and makes using them easier/quicker.
kythri
Lebanon, OR
Yeah, stubbies and midget wrenches are two totally different things.
My stubbies have helped out on a number of jobs.
Right now, shopping around for the GearWrench Stubby Flex Head sets in Metric and SAE - hoping to find another GW BOGO deal for them, but not having much luck...
pbon
I find stubbies useful. I have ratcheting as well but the bigger head often does not fit where I need it to go.
Stuart in MN
Minneapolis
I think the question is, have you found yourself in a situation where you needed a stubby wrench? If not, then they probably won't be that useful. As a reasonably serious DIYer, I can't think of a time in the last 50 years where I wished I had one.
KnurledNut
n/a
The comments have pretty well answered your question, but i will add that i have found the S.O. SHORT wrenches to be a VERY useful size. These are longer than the midget but shorter than standard. I.E. a 10mm wrench is 133mm vs. a midget at 98mm.
Qualitytools
SOCAL
They come in handy In tight spaces but other wise you can’t get enough leverage on them to break a fastener loose. I have a set I hardly ever use it and most of my work is on automotive
Onefastgsx
Indiana
The thing I realized with stubby wrenches is you dont realize how incredibly useful and handy they are until you have a set. I got by for years never really giving them much thought. But then I was given a set for Christmas that are ratcheting with swivel heads, and they have become some of my most used wrenches.
I would encourage anyone that doesnt own a set to buy them
