Midrise lift stuck up
blackgold
Hey folks I've got an autokato 8k midrise lift that's stuck up now. It was stuck up 6" from the ground with my car on it. With lots of wood and tomfoolery, I got the car off and started playing with it to figure out the issue. Now it's stuck higher up. When you press the down button, it will raise up to clear the locks then just kind of rest there. I did notice one side was a little lower than the other but they're connected left to right. Others said piston seals probably out but now I can't get to the pin because it's blocked by lift arms. So if it's a bad seal my assumption is it would be the side that was a little higher. Question is what's the best way to proceed safely as a one man operation. I need to get it down for now so I can get my car back in the shop. Thanks!
chinboys
build a ramp at the current stuck lift height and drive the car off.
if you do it right, you might be able to return the wood to the store if you didn't cut it or put too many screw holes in it.
blackgold
The photos show the wood I used. Car is off the ramp.
chinboys
? but it is now on the blocks.
how do you get it off the blocks?
a wooden ramp. not the lift's ramp.
or use a car jack to lift each wheel off the block that it is on back onto the ground, do it for the front wheels first.
then drive the car forward and make the rear tires sit atop the blocks.
then use car jack again to lower each rear wheel to the ground by removing the blocks.
blackgold
Wood on the back. CR ramp on the front. I drove it off. You can see it in the picture.
ericm
Southern Oregon
I think leaking seals would just cause fluid to leak out of the cylinder past the rod. A leaking piston seal would not prevent the cylinder from retracting. If it leaked more than the pump delivers then you would not be able to raise it.
If it was me I'd put jacks under the lift, get it off the locks and ensure that the locks do not re engage, and then disconnect the cylinder from the valve. On normal lifts you raise the lift up to get it off the locks and then open a hydraulic valve to let fluid out of the cylinders and lower the lift. It sounds from your description of the down button that there's not a physical valve to open? Maybe whatever opens the valve is not working properly. If disconnecting the hose allows you to lower the lift with the jacks then you know that it's not the cylinder.
Fixr
SW VA
And be sure to have a bucket handy.
ItsNemo
Canada
My Bendpak mid rise has air actuated lock releases...I've had a leaky air line that caused the lock not to release. Just used a pry bar to lift the lock over the catches until near the bottom then fixed the air line.
So my suggestion would be check the locking mechanism is releasing fully :)
Cruzan80
Denver, CO
Not the same brand, but I have one that is doing this. Best guess so far is that it is hydro-locked and fluid got around the seal somehow. Used a buddies forklift to disconnect the cross-members from the ram, still stuck outwards due to not able to get the ram off the bottom of the frame. Once I do, going to take it apart and replace seals.
ericm
Southern Oregon
Single acting cylinders have a vent in the side that does not get fluid. Otherwise the trapped air would prevent full motion or blow the rod seals. If fluid is leaking past the piston, it would come out the vent once there was enough of it.
Cruzan80
Denver, CO
Not sure what to say. Mine looks to have only a single port, but it rose under its own power, but didn't return. Even with some pressure from forklift tongs on top to "start" it going. Now the uppers are released, and the rod is still stuck in the out position (has been for some time). May be the piston seal is covering the vent port, or other debris got in there?
