mig stainless steel
countryss
New York
I got to weld in piece of steel to replace a pitted piece of stainless. it is not anything structural just cosmetic. if this is possible can i mig it or will the two metals oppose?
gte718p
Can be done, but it will not be pretty nor stainless anymore.
iagsxr
Vinton, Iowa
My local Farm Fleet type store keeps stainless wire in 2 lb. rolls. My welder won't take those little spools so this spring I ended up welding a stainless motor plate w/regular mig wire. So far it's held up fine.
Told a buddy about it after the fact. He said he's in the same boat so he keeps a little roll of stainless around and just pulls what he needs off the spool, strings it out and the wire feeder'll pull it through. Duh for me.
toxicz28
NY
Yes it can be done. Use 309L wire for the dissimilar metals and a tri-mix sheilding gas.
atari
Carroll, Ohio
It just contaminates the stainless with carbon and makes it prone to rust. I do it all the time when Im building work stations at work. Most of the scrap we have laying around is 316/17-4 and the benches are usually mild square tube. Any tabs or hooks end up to be stainless. If the stuff is gonna be outside or in a salty environment I would be kinda concerned unless you could paint it. Inside though, run it and forget it.
Ben Iv
Oklahoma
We used to weld 304 stainless to carbon with 309L fluxcored wire with 75/25 mixed gas with no problems. And the welds looked great.
