MIG wire size
shamrock12
South Dakota
I have a new Millermatic 212 welder that I am setting up in my hobby shop. I plan to be welding mostly 1/8" to 1/4" material. Mainly mild steel. Maybe some thinner materials from time to time but nothing thinner than 1/16". Which size wire would be better suited for the material I intend to weld; 0.030" or 0.035"?
Stooge
South Shore, MA
I use .030 for 95% of the stuff i do, from 1/4" to 20ga. I do keep a small spool of .023 for some smaller sheet metal projects but usually get by with the .030
brownbagg
i really like the small 025 in the smaller mig machine, they come alive with it, but those machine are only good for 1/8 and below
gearhead1
NC
I run 0.030 in my Miler 180. I go even thinner than 1/16 with it. You'll be happy with it.
fnieto
Tucson,Arizona
I hate to be the odd ball on this one, but .035 would yield perfect welds in this material range. Also provides for a faster deposit of filler resulting in less noble gas consumption.
Not saying .030 wouln't work.
Chuck122
Québec, Canada
I agree. I use .035 in my Mig. I have done body work with it, and once properly adjusted it did pretty good. Altought I have never used .030, I'd guess smaller wire would not allow you to weld as hot on thicker stuff. Given that .035 is serviceable in sheet metal and probably more effective in thicker stuff, I'd say take the extra .005.
Engine
Kentucky
I get a little better looking welds using the .030" wire. It seems to be a little easier to control in the vertical up or overhead positions than the .035" gauge. I've used it on everything from 16 ga. to 1/2" with no problems.
Jackfre
N CA
I run the .030 or .035. Net/net it is all about you and the practice you put in to get to know the set up. If you are doing flat work on a table it is all pretty easy. Position welds are another matter and only practice will pay off. Go ahead, ask me how I know:lol_hitti
zengarage
I vote for .035. I only use .035 and .045 these days. Haven't used .030 in a long time.
