modelaratrod
- Joined
- Aug 3, 2011
- Messages
- 24
I recently picked up a few of these military diesel heaters and got a few of them up and running, what I'm looking to do is use one to heat my shop and on to heat my bus/tiny house and I would like to feed it with an electric fuel pump off of the vehicle's diesel tank. Fuel is currently provided by a Jerry can turned upside down three or four feet off of the ground feeding through a fuel strainer then into some kind of a float setup and onto a solenoid fuel pump that meters small doses of fuel into the burn chamber.
I'm thinking a two PSI electric solenoid fuel pump should be plenty but I can't find any specs of the Tillotson fuel float in the last picture it appears to just be a reservoir controlled by a float that the electric metering pump siphons out of. I do not see any part numbers just the manufacturer name cast in the top.
Do any of you have experience with this heater and the fuel pressure requirements to run it?
Thank you in advance.
