Mill/drill, lathe
Milehighxr
Lpngmont CO
Mead CO 80542
Price
$3600.00
I no longer I have need for these items, as need space more than I need these. I am moving in the not to distant future and will not be taking them with me.
Lincoln mill drill, made in Taiwan round column with an additional 4ft column. Comes with a vise that is mounted to a rotateable base(not an indexer), and a few R-8 collets, drill chuck, and some end mills. Wired for 110v household power, and can be rewired to 230 single phase for better efficiency. Is on a mobile cart so it can be moved around the shop when not in use. Comes only with the vise mounted on the table, not the Morgan vise, or the trans holding fixture.
This is a turn key set-up start making chips the instant you unload it into your garage.
$1800.00 for mill and its accessories only.
Jet 9x20 metal lathe comes with, mobile stand, chuck, a few MT2 collets, tailstock, rest, quick change tool post(piston type), and a few tool holders and tool bits, 4 jaw chucks, larger 3 jaw chuck, faceplate, and material to make a mount plate for other items. Also comes with about $500.00 worth of tool bits.
This is a turn key set-up, start making chips the instant you get it unloaded in your garage.
$1800.00 for lathe and its accessories only.
Prefer to sell together, but priced as individual items.
All items as is no warranty expressed or implied. Buyer to assume all responsibility for moving items.
If you want both the price is $3600.00. Use google to find exact details for the machines.
