Feathering may not be the best term but basically I have noticed there are certain spots on the dial where Autoset jumps to a much higher voltage/speed with only a slight movement of the knob. The dial is only marked in whole numbers but if you picture moving from a position of say 6.9 to 7.1 a big increase results. I assume this is just the nature of the beast but it has me wondering what happens behind the scenes with Autoset.
So how does Autoset work? Is each position on the dial a discrete voltage/speed combination or does it work off of some sort of feedback from the arc and continually adjust?
My machine is a circa 2010 MM180 which is the transformer version and basically a derated MM211
